Most of this info is from learnelectronics video below:- 120MHz single channel- 40MHz dual channel- equivalent max sampling rate 500MSps- looks like it uses MCX connectors- storage depth 12.8div (?)- vertical sensitivity 50mV-100V- time base 6nS-50S- trigger auto/normal/single, rising/falling edge- signal generator: sine/triangle 100kHz, square 3MHz, 0-3V- 320×240 2.4" display- 124×80×35mm, 187gAt Banggood for around US$80: https://www.banggood.com/MUSTOOL-2IN1-120MHZ-Dual-Channel-40MHZ+2-500MS-or-s-Handheld-Digital-Oscilloscope-+-Function-Signal-Generator-MDS120MC2-p-2011184.html?cur_warehouse=CNA short review by learnelectronics, he wasn't very impressed and thought it was a bit too expensive: https://youtu.be/JNNQ12k7EK8
