I read about the overdriving, but no one wrote that this happens zero level binding disappears from the channel marker.Is the zero level loss "normal" when overdriving DS1054?
My DSO203 for $ 100, I look on the same signal and it does not lose the zero level to the minimum sensitivity - 50mV.
It's a bad surprise for me.
FungusIt no problem, is it the way it should be?
It happens like that on all Rigol Scopes.
Has Rigol supplied a link to this firmware on any site other than its Chinese site? Is there any potential issue with installing the firmware on a scope purchased in North America? I assume that the firmware should be identical for all regions, but I don't understand why it's only showing up on a Chinese language site.
Rigol just isn't that organized, apparently, when it comes to their firmware release process. C'est la vie.Folks here have installed it on NA scopes just fine.
I installed first the Chinese site, then the one that modified janekivi, to correct the error of spelling of "pluses" by pulses, probe back to install the original one worked and then I returned to install of janekivi, so everything perfect.in spanishyo instale primero la del sitio chino, luego la que modifico janekivi, para corregir el error de ortografia de "pluses" por pulses, probe volver instalar la original funciono y luego volvi a instalar de janekivi, asi que todo perfecto.
is there a download link where I can get the file without registering?
