Hello,
it's passed a bit of time from my last teardown.
Recently I scored a pair of interesting used devices on ebay.
I was searching for an electrometer, just for the fun of having one in my 'home' lab,
I stumbled accross a seller that had a nice keithley 616 (that will be part of a another thread)
and also a stereo inspection microscope. I couldnt pass on them so I bought both, and here is it :
a Cambridge Instruments (Bausch and Lomb) StereoZoom 7 in very good ahestetic conditions.
Unfortunately the seller didnt had the stand or the eyepieces, but it's is enough fot the price.
This instrument is a “Greenough” microscope, i.e. a the light path that arrives to each eye is
fully separated, no optics are shared between the two paths.
This is different from “Common Main Objective” device, like my other microscope,
a Lomo MBC-10 where the last optic is shared.
There are some benefits and downsides for each configuration.
![](https://www.eevblog.com/forum/testgear/cambridge-instruments-(bausch-lomb)-stereo-zoom-7-teardown/?action=dlattach;attach=98923;image)
![](https://www.eevblog.com/forum/testgear/cambridge-instruments-(bausch-lomb)-stereo-zoom-7-teardown/?action=dlattach;attach=98925;image)
The unit has a coaxial illuminator, that injects light directly in the light path, illuminating the
field through the same optics that are used to pick up the image. The illuminator is easily
separated from the unit,
![](https://www.eevblog.com/forum/testgear/cambridge-instruments-(bausch-lomb)-stereo-zoom-7-teardown/?action=dlattach;attach=98927;image)
but it seem that each illuminator is adjusted to the main unit
![](https://www.eevblog.com/forum/testgear/cambridge-instruments-(bausch-lomb)-stereo-zoom-7-teardown/?action=dlattach;attach=98929;image)
The illuminator itself contains a colored filter wheel and a pair of prisms that deflect
the light in the mai path, while letting pass trough the image that goes to the oculars
![](https://www.eevblog.com/forum/testgear/cambridge-instruments-(bausch-lomb)-stereo-zoom-7-teardown/?action=dlattach;attach=98931;image)
![](https://www.eevblog.com/forum/testgear/cambridge-instruments-(bausch-lomb)-stereo-zoom-7-teardown/?action=dlattach;attach=98933;image)
![](https://www.eevblog.com/forum/testgear/cambridge-instruments-(bausch-lomb)-stereo-zoom-7-teardown/?action=dlattach;attach=98935;image)
![](https://www.eevblog.com/forum/testgear/cambridge-instruments-(bausch-lomb)-stereo-zoom-7-teardown/?action=dlattach;attach=98937;image)
