If folks want a MP3 player plus a multimeter, why not buy a mooshimeter instead?
I think Scott said he played with one.
Yes, I did buy one, ran it in some testing and well. I only review and do videos on products I keep, like and woild recomend to others. It went back.
Biggest issue, it depends on BT fully, no local buttons or display. And when the app is so unstable you can’t keep a connection then it makes it worthless. The update rate seemed impressive over BT to the device paired, they have that down. Graphing, VA, resolution, and very sensative considering it has no shielding.
When BT works, or I should say when the app works, it worked good. It was monitoring in the besament, and I was able to walk up 2 stories to the main lab and keep connection, so range wasn’t the issue.
Same issue as the 121GW, if you want that SD card put you have to take it apart. But you could transfer the logs to the opine over BT also.
And then the app, crash, crash, crash, oh come on. The answer was we are working on an update. Just constant app updates, fix these bugs, introduce new bugs. If you have to depend on the app and only the app that can’t stay connected then it’s not usfull to me. You could connect, start logging and disconnect. But you might not be able to connect again to see how things are going, or it could take a few tries.
I hate to say it, but software is everything these days. People will buy something because it has an app and can share on Facebook. If you advertise an app or software with s product and it’s really basic and useless, or full of features but crashes all the time then that’s all that will get reviewed and what people will remember is that app. So if you make an app for your device, support, make sure it works before releasing the update, and stay on top of it. It could be the downfall of a good product that may be perfectl without an app. But they won’t review or remember that, they will on,y complain how the app is not stable and won’t work. But you need the app for mosshiemeter, you can’t run it without the app, so bad combination and it was returned three days after buying it.
