Author Topic: New EEVBlog-Branded Multimeter Coming?  (Read 172119 times)
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
Re: New EEVBlog-Branded Multimeter Coming?
« Reply #425 on: January 11, 2018, 09:10:23 pm »
A short clip comparing the autorange speed of some portable DMMs I have. Sorry about the shaking; I did not have my tripod with me. Ah, the video has no audio.
(edit) I posted a video with better quality, no shaking and better lighting. I also added 100k ohm measurements to the mix and audio to facilitate the timekeeping.
https://youtu.be/EWZ0OSjYnvg
« Last Edit: January 13, 2018, 12:39:08 pm by rsjsouza »
« Reply #426 on: January 11, 2018, 09:31:42 pm »
Would a 7 sec autorange meet anyone's minimum standards ?
And does REPEATING the same point 8-10 times on different threads with ZERO hands on use make you useful in the discussion or just LOUD?
Offline dr.diesel
« Reply #427 on: January 11, 2018, 09:48:54 pm »
Not his fault we have multiple threads talking about the same thing, and his comment is SPOT on, don't need to own one to make that observation.
The following users thanked this post: 3db
« Reply #428 on: January 11, 2018, 10:10:44 pm »
But to keep harping on that same point?? It seems more about trying to whip up some sort of online frenzy about a point that will take a little time to fix in firmware, bleating incessantly about it won't make it magically fixed or even happen sooner.
Offline TheSteve
  • Living the Dream
« Reply #429 on: January 11, 2018, 10:17:28 pm »
Did you try the u1282a in both the 9 and 40 updates per second modes?
VE7FM
Offline dcac
« Reply #430 on: January 11, 2018, 10:28:54 pm »
Thanks rsjsouza for the timing video, I have calculated U1273A and U1282A as they both goes down to milliohms resolution. Eyeballing when they seem to present a reasonable "useful" value.
U1273A
0-5vdc  = 1.6 Sec
0-30vdc = 1.5 Sec
0-89vac = 2.3 sec
0 ohms  = 1.6 sec & 1.8,sec
20Kohms = 0.9 sec & 0.8 sec
U1282A
0-5vdc  = 0.7 Sec
0-30vdc = 2.5 Sec
0-89vac = 4.5 sec
0 ohms  = 3.5 sec & 3.6 sec
20Kohms = 2.2 sec & 2.2 sec
121GW
0 ohms = 7.4 sec
edit: added 121GW 0 ohms from other video (Robert Culver)
« Last Edit: January 11, 2018, 10:39:42 pm by dcac »
Offline rsjsouza
  • Eternally curious
« Reply #431 on: January 11, 2018, 10:54:50 pm »
I didn't, as at 40u/s the number of counts is reduced by tenfold, which turns it into an oversized UT136C.  :-DD
At any rate, I just ran it here and it mostly affected the voltage measurements:
instantaneous for 5VDC
0.5s for 30VDC
2s for 89VAC
The ohms performance is only marginally improved:
About 3s from infinite to zero
About 1.5s from infinite to 20k
steverino
  • Guest
« Reply #432 on: January 12, 2018, 03:04:35 am »
 :scared: "bleating", "frenzy", "LOUD", Hmm, I do sense someone is frenzied.   :scared:
 :-DD
Ok, I'll stop now. Going back into my cave...
« Reply #433 on: January 12, 2018, 03:12:07 am »
Yep  :-DD
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #434 on: January 12, 2018, 10:48:38 am »
I am looking forward to seeing reviews of the more complex features, for example reading the power of a 110/220 LED bulb, showing  the BT,  trying some long term data logging to the memory card (over night sort of thing).   For those of you who have received their meters and have taken the time to run some  of these early test,  I appreciate your efforts.
I tried the SD card data logging overnight with 5V and 50V.
My room temperature was moving between 24C to 19C in the morning.
I change the file from csv to zip file to attach here because of the file size.
« Last Edit: January 12, 2018, 10:53:31 am by fanOfeeDIY »
The following users thanked this post: Tsippaduida, Iagash
Offline joeqsmith
« Reply #435 on: January 12, 2018, 12:45:40 pm »
Thanks!!  This is very good news.  After hearing about the VA, I was starting to wonder.
Offline Iagash
« Reply #436 on: January 12, 2018, 12:52:35 pm »
I am looking forward to get the meter in a month or two and check it out (I will do a review). The main reasons I got the meter was the low burden voltage and the 15V diode mode. I wonder if the VA mode is useful, I will probably continue to use my meter with a real W mode.
I'm looking forward to your review.
Thanks for all your other reviews on your website. It's my first stop whenever I need a new battery or charger. :-)
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #437 on: January 12, 2018, 01:06:42 pm »
It was also a happy surprise for me with the really consist measurement numbers considering 50,000 counts with 0.05% in the spec.
Offline HKJ
    • Tests
« Reply #438 on: January 12, 2018, 01:39:55 pm »
I also hope to make the multimeter reviews useful for selecting a meter, but I need more for that, at the moment there is only 18 reviews.
Offline Scottjd
    • YouTube Gadget Reveiws
« Reply #439 on: January 12, 2018, 05:18:05 pm »
Well we have the miliohm meter in common, the YR1030 that you can test interns,battery resistance with.’oh, but the way. Ignore my message on the other site, I found the manual and translated it.
In fact if you want a copy to post on your review in PDF fr]ormst just let me know.
Thanks,
Scott
Please be sure to check out my YouTube channel and subscribe if you like the videos. https://www.youtube.com/c/GadgetReviewVideos
By people subscribing and giving thumbs up I know what I am doing is still wanted and adding value, then will continue to release new videos. Thank you for your support.
Offline ez24
  • L.D.A.
« Reply #440 on: January 12, 2018, 07:08:30 pm »
HKJ - something that would help me and maybe others - put a link to your great website in your profile so it shows up every time you write something.  Every time you write something, I try to find it and fail. (also I want to add it to #3).
If not how about give it to me one last time.
Thanks and keep up the outstanding work. For those that do not know - HKJ has the best site for battery and battery charger reviews.
Offline maukka
« Reply #441 on: January 12, 2018, 07:16:22 pm »
You can click the globe below his name which leads to lygte-info.dk
The following users thanked this post: ez24
Offline HKJ
    • Tests
« Reply #442 on: January 12, 2018, 07:22:11 pm »
Click the globe to the left, it leads directly to my website (I fixed that last time I got a complain about it).
The website do not use a framework to give a good layout, but is old style html, this makes it very fast to navigate if you know how to use your browser.
I publish many reviews, that is not the same as they are superficial, due to automation there is usual a lot of testing behind each review.
Offline Fungus
« Reply #443 on: January 12, 2018, 08:03:06 pm »
Beep beep. Beep. Beep. Beep. Beep!
FOR THE LOVE OF GOD....
Skip to 6min 32sec
Hey, at least that one doesn't play music at you!
Skip to 1min 15sec
Offline ez24
  • L.D.A.
« Reply #444 on: January 12, 2018, 08:41:48 pm »
Thank you - I did not know this  :-+
Offline rsjsouza
  • Eternally curious
« Reply #445 on: January 12, 2018, 09:25:16 pm »
Skip to 6min 32sec
Skip to 1min 15sec
My U1273A did the same... (skip to 15:15)
https://youtu.be/w7CaY4Ewzus
Offline joeqsmith
« Reply #446 on: January 13, 2018, 12:45:23 am »
Wait, the 121GW can't play music can it??   I know my UT90A could.   :-DD
https://youtu.be/svJXiMMZzcQ
Offline GameProgrammer79
  • Country: ae
    • IoT Daemon
« Reply #447 on: January 13, 2018, 02:02:22 pm »
That seems to be the most critical issue found in 121GW so far.. :-DD
Folks I am getting back in Electronics game after 18 odd years :)
Offline coromonadalix
« Reply #448 on: January 13, 2018, 07:40:47 pm »
Do you want it to play mp3 from the sd card  lolll
Offline ez24
  • L.D.A.
« Reply #449 on: January 13, 2018, 07:46:24 pm »
Yes I think this a good feature for a meter.
Edit: Because I am an MP3 player addict like the MM addicts here.  I think I have bought every MP3 player made since the Rio
« Last Edit: January 13, 2018, 08:14:27 pm by ez24 »
