Author Topic: New EEVBlog-Branded Multimeter Coming?  (Read 174708 times)
Offline dcac
Re: New EEVBlog-Branded Multimeter Coming?
« Reply #325 on: January 09, 2018, 08:07:22 pm »
I’m a bit concerned/surprised with the initial reports that auto-ranging seems slow on the 121GW. I seem to remember Dave often pointed out if a DMM seemed slow in his reviews, and also the Brymen meters seems quite fast both in update-rate and auto-ranging so I was hoping the 121GW would at least have similar speed as the Brymen.
I’m backer 924 btw, so I’ve yet to test anything myself. And my initial impression was that the 121GW did not really seem slow when Dave used one of the prototypes in his videos.
Online Fungus
« Reply #326 on: January 09, 2018, 08:11:54 pm »
Just because he's a qualified multimeter critic doesn't mean his own meter has to be perfect. Maybe he's just trying to sell a decent meter and make some money while he's at it.
(He'd have to charge a lot more for the mythical 100% perfect meter.  :popcorn: )
« Last Edit: January 09, 2018, 08:14:57 pm by Fungus »
Offline dcac
« Reply #327 on: January 09, 2018, 08:22:19 pm »
should I take your statement as a confirmation that the 121GW is indeed slow?
and btw, did I ask for a mythical 100% perfect meter(?)
Online IanB
« Reply #328 on: January 09, 2018, 08:25:39 pm »
It didn't seem slow when I watched someone test it.
Online Fungus
« Reply #329 on: January 09, 2018, 08:32:46 pm »
I wouldn't know.
I'm just saying that because Dave has criticized speed in his reviews doesn't necessarily mean his own meter has to be faster than every other meter ever.
Offline dcac
« Reply #330 on: January 09, 2018, 08:36:33 pm »
I guess everything is relative but here it seemed slower than I was expecting from a meter with 5 updates/sec.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #331 on: January 09, 2018, 09:00:08 pm »
I don't know about the 121GW, but I don't recall seeing anything faster than the Brymen meters I have used (I currently have a BM857) and the Fluke 179 I had.
Keysight U1233A/U1273A are quite fast as well, in contrast to their new flagship model U1282A.
Offline dcac
« Reply #332 on: January 09, 2018, 11:08:02 pm »
Thanks for your input, yeah I agree the Brymen are fast. And the 121GW also goes all the way down to milli-ohms resolution so taking a bit longer would be understandable, still -  auto-ranging from open circuit to short seems about 5-6 sec, ouch!
I’m surely hoping that a fastmode with lesser resolution can/will be implemented, that i.e. puts the meter in a 5000 count mode. If it isn’t a FW bug that’s slowing the meter down.
The following users thanked this post: rsjsouza
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #333 on: January 10, 2018, 12:02:45 am »
Just uploaded another video of the 131GW Multimeter. This time it is joke video for fun :)
EEVBlog Meter Joke Review
https://youtu.be/zlYwwf2PTvg
The following users thanked this post: rsjsouza, ez24
Offline GameProgrammer79
  • Country: ae
    • IoT Daemon
« Reply #334 on: January 10, 2018, 12:20:41 am »
cant use 121GW to eat .. such a shame.. imagine forgetting to bring chopsticks to office ..  :-DMM
Folks I am getting back in Electronics game after 18 odd years :)
The following users thanked this post: fanOfeeDIY
Offline joeqsmith
« Reply #335 on: January 10, 2018, 01:53:37 am »
I had wondered if it could not run in a low res mode then switch to high res to get it to lock in faster.  The 121GW uses the same front end chipset used in another meter that Dave had reviewed and I though the settling time was discussed back then.   I would guess some of the people who bought one have more than one meter.  Maybe others will do a side by side comparison to give you a better idea how it compares.
Online Fungus
« Reply #336 on: January 10, 2018, 02:08:59 am »
Even better: Do a binary chop instead of a linear search (ie. start in the middle)  :popcorn:
The following users thanked this post: exe
Offline joeqsmith
« Reply #337 on: January 10, 2018, 03:08:04 am »
SAR?
Offline markb82
« Reply #338 on: January 10, 2018, 03:11:15 am »
I looked at the chipset and I think you could do a lower count fast sampling mode which could help with auto-ranging.  Even if it doesn't, it would be nice to have a faster sampling mode.
Offline joeqsmith
« Reply #339 on: January 10, 2018, 03:23:03 am »
Looks like the UNI-T UT171B also uses that front end along with the HPAK U1282A.   These would be good comparisons.
Offline markb82
« Reply #340 on: January 10, 2018, 05:36:01 am »
AD1 of the HY3131 chip has a max sample rate of 640 sps (using 4.915Mhz crystal and the lowest prescalar of 256).  :popcorn:
Offline exe
  • self-educated hobbyist
« Reply #341 on: January 10, 2018, 09:15:52 am »
Yeah, this also surprised me why using linear search? :(. With 50k counts just one measurement at mid-range it is enough to fully determine the required range, imho. So, no need for search most of the time.
I was also thinking about a dedicated comparator that would just "know" which range is needed. But it might be possible to just activate a high sample rate at an overload event (if available, the manual says max sample rate is 5 samples/s, but there might be a higher rate at reduced resolution).
I'd also try to align numbers to the left so when it down-ranges it would just display extra digits of resolution at right.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #342 on: January 10, 2018, 11:38:01 am »
Looking at the video, that autorange time on ohms is totally unacceptable.
Fluke 87 takes a second.
Any more than this is simply broken.
Day Job: Mostly LEDs
« Reply #343 on: January 10, 2018, 11:59:56 am »
Presumably it's already doing fast sampling for the bargraph display - it should be using this for ranging.
Does kinda bring up questions of firmware quality if it's doing such basic things so obviously wrong..
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #344 on: January 10, 2018, 01:25:26 pm »
I just uploaded the review of auto rage time on measuring resistance on 121GW multi-meter, comparing with other two meters from Keysight and Hioki.
In the future the software updates might speed up the auto-rage but not clear at the moment.
The measurement speed on resistance by manual rage on 121GW had no issue.
I was thinking to make it short but became about 14 minutes video.
I spent too much time on rendering too :)
EEVBlog 121GW Multimeter Resistance test with auto-range slow?
https://youtu.be/dyM0F7y3bj4
The following users thanked this post: thm_w, Bud, exe, iainwhite, gamalot
Offline dcac
« Reply #345 on: January 10, 2018, 03:37:09 pm »
I tend to agree, the auto-ranging on 121GW isn't just "slow" - it is unusable.
The following users thanked this post: Russ
Offline HKJ
    • Tests
« Reply #346 on: January 10, 2018, 07:11:09 pm »
That makes most of the multimeters on the market broken, except the manual range ones.
Offline evava
  • Country: cz
« Reply #347 on: January 10, 2018, 07:31:00 pm »
from my shop:
(ohms autoranging from open to short)
UT61e - half second, sometimes almost instantly
UT181a - 1.5 second
87V - 1 second
289 - 2 seconds
and AN8008 about four seconds, too slow.
Can someone please try the same (speed of autoranging) on capacitance range, for example from open to 20uF ?
« Last Edit: January 10, 2018, 07:39:00 pm by evava »
Offline markb82
« Reply #348 on: January 10, 2018, 07:38:10 pm »
Had a 100uF on my bench.
Capacitance:
    121GW open circuit to 100uF -> 4.5 seconds
    U1272A open circuit to 100uF -> 1.5 seconds
    BM235 open circuit to 100uF -> 3.0 seconds
Resistance:
    121GW open circuit to short -> 9.5 seconds !
    U1272A open circuit to short -> 2.5 seconds
    BM235 open circuit to short -> 1 second (maybe even less)
« Last Edit: January 10, 2018, 07:50:20 pm by markb82 »
Offline markb82
« Reply #349 on: January 10, 2018, 07:40:08 pm »
I think the firmware needs some serious love.  Perhaps an opportunity for a GitHub open-source project once Dave releases the schematics?
