Author Topic: New EEVblog BM786 Multimeter  (Read 158320 times)
Offline EEVblogTopic starter
Re: New EEVblog BM786 Multimeter
« Reply #25 on: October 14, 2020, 12:46:04 pm »
Really nice. I have some questions:
Does it work well with rechargeable AAA batteries?
Does it come with a Cal certificate?
It should work ok with rehcargables:
https://www.eevblog.com/forum/testgear/us$150-class-multimeter/msg3077681/#msg3077681
No cal certificate, just like other Brymens.
Offline BravoV
  • +++ ATH1
« Reply #26 on: October 14, 2020, 12:52:11 pm »
+1 , and also Lithium cells ? As these have tad higher voltage.
« Reply #27 on: October 14, 2020, 12:54:11 pm »
BTW, I don't actually have the blue version yet, it's on the courier truck. I only have the red proto version.
« Reply #28 on: October 14, 2020, 12:54:33 pm »
Yes, confirmed ok by Brymen.
The following users thanked this post: BravoV, Jacon
Online tszaboo
« Reply #29 on: October 14, 2020, 01:02:45 pm »
Well, 3.55V/3= 1.18V. That is around 50% DoD of a NiMH, so not perfect.
I guess we buy a pack of alkaline then.
Online 2N3055
  • Country: hr
« Reply #30 on: October 14, 2020, 03:27:33 pm »
A question?
Will firmware be field upgradeable?
« Reply #31 on: October 15, 2020, 02:25:27 am »
Technically there is a programming header inside, but Brymen are super secret about their processor used. So that's a "no" for now.
At least it's programable, unlike the BM235 which uses an OTP part.
The following users thanked this post: 2N3055, Marco1971
Offline Monkeh
« Reply #32 on: October 15, 2020, 03:43:50 am »
I'd say send one off for a decapping and see what it is, but I wouldn't want to hurt a relationship for idle curiosity.
« Reply #33 on: October 15, 2020, 10:49:32 am »
My guess is one of the really low end asian brands. On both the BM235 and this one they talk about struggles having enough memory to add new functions, so it's very memory limited.
The following users thanked this post: Marco1971
Offline Electro Fan
« Reply #34 on: October 15, 2020, 07:48:14 pm »
BM786 looks really good but any chance it actually weighs 635g?  Fluke 179 is similar in dimensions (although can't say for sure about the depth/thickness front to back as far as case/probe holder vs. meter itself), but the 179 is 420g.  Also, compare the weight and HWD in the 786 manual to the weight and HWD of the BM869S.  Maybe the 786 manual specs for weight (or otherwise maybe HWD) need an edit?  Just curious.
« Reply #35 on: October 15, 2020, 10:41:16 pm »
Yeah, mistake. It's 414g with batteries. My 77-IV is 408g.
« Reply #36 on: October 15, 2020, 10:45:09 pm »
vs the 77IV for those curious.
The following users thanked this post: Marco1971, jlo, JOSM
Offline sdt
« Reply #37 on: October 15, 2020, 11:05:03 pm »
How do the DC+AC modes work?
Does it flip back and forth between separate DC & AC measurements?
Offline Electro Fan
« Reply #38 on: October 15, 2020, 11:30:49 pm »
Your new meter is going to be very popular.  Congrats!
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #39 on: October 16, 2020, 05:35:40 pm »
I don't know about this meter, but in my BM857 (also single display) the AC+DC adds the DC with the AC RMS value of the input, and you can cycle between AC, DC and AC+DC modes using the buttons.
Online HKJ
    • Tests
« Reply #40 on: October 16, 2020, 06:24:38 pm »
AC+DC is always a single value compromised of sqrt(sqr(AC)+sqr(DC)), the question is how the meter does this.
Most meters reads a AC value, then a DC value and then do the calculation, i.e. reducing the update rate, a few meters may be able to do a combine AC+DC measurement in one conversion. When doing separate AC and DC measurement there is also a issue about the time needed to do the switch between them.
The following users thanked this post: tooki, Trader
Offline MosherIV
« Reply #41 on: October 16, 2020, 07:02:33 pm »
I think te question about ac+dc is more about how is it displayed with only single display.
My Fluke 187 does it but has dual display.
The following users thanked this post: rsjsouza
Offline rsjsouza
  • Eternally curious
« Reply #42 on: October 16, 2020, 07:55:22 pm »
That is how I understood the question when I provided my reply above.
Offline ogdento
« Reply #43 on: October 16, 2020, 10:29:26 pm »
This is nearly the only meter I'd ever need.  My only gripe is there's no low-z (on the 786)... will there be an eevblog-blue 789?
Offline sdt
« Reply #44 on: October 16, 2020, 11:45:36 pm »
Thanks for the replies, that clears up a lot.
Neither of my two meters (ut139c & an8008) have any sort of combined AC & DC modes. I've seen meters with dual display, but not come across DC+AC before.
To be honest I'd never even considered what the AC mode would report in the presence of a DC offset. From the comments I take it the AC mode is AC coupled and ignores the DC offset, and the DC+AC mode is the numeric sum of what the DC and AC modes would report.
Offline ve7xen
    • VE7XEN Blog
« Reply #45 on: October 17, 2020, 12:14:10 am »
Yes, though it is the geometric mean, not sum. It is giving you the total RMS value of the input, rather than the RMS value of the AC or DC components only (which is what you [ideally] get in those respective modes).
I think there are some DMMs out there that don't actually AC-couple the AC range, so YMMV, but this is what would normally be expected.
73 de VE7XEN
He/Him
The following users thanked this post: Huluvu
« Reply #46 on: October 17, 2020, 06:14:13 am »
No, I'm not allowed to sell it, as there is an official Australian dealer who has already said they want to carry it.
Good luck trying to buy it from them: https://www.cabac.com.au/
I don't know why they bother with Cabac, I'd sell 100 times the meters they would.
« Reply #47 on: October 17, 2020, 06:17:44 am »
This is why the AC+DC mode is on the DC range switch. It can measure DC and then switch in an AC coupling cap, and then it display the  combined DC+AC value.
« Last Edit: October 17, 2020, 06:19:46 am by EEVblog »
Offline wolfy007
« Reply #48 on: October 17, 2020, 07:38:50 am »
I remember them, their online store is still shit I see, I remember I ended up buying a Brymen meter I wanted from Europe instead of them.
Offline Wytnucls
« Reply #49 on: October 17, 2020, 11:02:46 am »
On my multimeter (UT71D), the voltage AC+DC is constantly converted to true RMS by the AD636.
Vrms= Avg x [Vin^2/Vrms]
If AC only is required, Vin is routed through a capacitor before reaching the true RMS converter.
The AC/AC+DC switch works on the V AC selector position only.
The DC component is read on the V DC selector position.
« Last Edit: October 17, 2020, 01:05:10 pm by Wytnucls »
