Author Topic: Show us your square wave  (Read 216775 times)
Offline joeqsmith
Re: Show us your square wave
« Reply #525 on: June 15, 2024, 01:22:31 am »
GigaWave with Tektronix S-52 tunnel diode head (<25ps Tr)
https://www.sjl-instruments.com/
Nice, what I would like to see the real time behavior, as 20..80% or 10..90% rise time changes over time :D
On a LeCroy easy to graph over time as rise f(t).
Better late than never.   Showing the output from the LiteVNA (low cost VNA).
Offline joeqsmith
« Reply #526 on: June 15, 2024, 03:42:00 am »
Showing the risetime drift using the latest software with tracking  enabled.  The Tektronix pulser is very slow.  There is a tradeoff between the drift, amount of and how fast the data is collected and the repeatability.   I would imagine if this pulser had a faster pulse rate, I could collect more data and this measurement would tighten up.
Still, less than 5ps over a span of 21 minutes.   Also they spec the scope for 40ps typical 80/20.   All of the measurements I have made fall below that.
Also shown after 50 minutes, it is starting to appear gaussian with less than 7ps.
« Last Edit: June 15, 2024, 04:01:30 am by joeqsmith »
The following users thanked this post: SJL-Instruments
