If you end up in electronics, than you don't need high voltage "stuff".
If you end up in industrial automation (PLC, 460 VAC 3 phase motors), than you WILL NEED high voltage "stuff".
If you end up in HVAC, you will need temperature and uA measurements.
If you end up in the field a lot, you will want none contact voltage detection too.
In conclusion. Figure on having Fluke 116 and 117, or their equivalents from other brands. The important fact is that you are a student and you don't know in what industry you will end up. What does it mean? Buy what you will use in your classes, buy it cheap and when you graduate, give it away or sell it because whatever you use in your classes is not going to be good enough for your job.
So. Buy cheap, but with solid reputation.
