Okay, I managed to watch most of the 215 minutes.
Some observations and comments.
A lot of the meters in your shootout are rebranded meters.
CircuitMate DMR6550 - rebranded CEM DT-932N (China)
http://www.cem-instruments.com/en/pro/pro-483.htmlKlein MM2000 - rebranded Fine 700 Instruments (Korea)
http://www.finest.co.kr/html/pro_02.htmlSouthwire 12070T - rebranded CEM DT9962T (China)
http://www.cem-instruments.com/en/pro/pro-481.htmlhttp://simvolt.ua/images/detailed/1/9962t_1.jpgBK Precision 2705B - rebranded Chung Instruments
Likely a variation of the CIE-162
http://www.loelectronics.com/en/product/DIGITAL-MULTIMETER/639UEI UTLDM2 - rebranded Mastech (China)
Likely a variation of the Mastech MS8237B.
http://www.p-mastech.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=208&category_id=3&option=com_virtuemart&Itemid=29&vmcchk=1&Itemid=29Extech 430 - likely a CEM rebrand due to tall exaggerated LCD digits, but I cannot find equivalent on CEM's website.
Tekpower TP40 - rebranded Velleman VA40 (China)
http://mastech.com.cn/html/en/products-va40.htmNotes:
1) The MOVs in most, but not all, of your multimeters are blue colored which you are mis-identifying as PTCs. For example, here is a picture of the Fluke 107 from
https://www.eevblog.com/forum/testgear/review-first-impression-of-the-fluke-107-multimeter/The two blue components circled in blue are MOVs. The green component circled in green is a PTC. The yellow circled component is a 1k ohm fusible resistor.
MOVs may also be silk screened on the pcb as MOV, SG (spark gap). On the Fluke 107, the MOVs are silkscreened RV1 and RV2.
In the Tekpower, the mustard yellow components are the MOVs (3) and the green components are the PTCs (2). I will leave it to you to identify the MOVs when you do the individual meter reviews.
If you are unsure, you can always measure the PTC and MOVs in circuit. A PTC should be around 1k ohm. A MOV will show 0L (out of range/overload) ohm.
Like everything else, there are different varieties of PTCs and MOVs in terms of quality, tolerance, voltage, etc ratings.
2) Extech EX430 - piece of solder inside the multimeter. Many Extech multimeters have soldering problems. I'm not 100% sure who makes the EX430 for them, but my own experience with a EX430 is documented here
https://www.eevblog.com/forum/testgear/extech-ex430-multimeter-teardown-photos/https://www.eevblog.com/forum/testgear/extech-ex330-quality-issue/https://www.eevblog.com/forum/testgear/teardown-extech-ex570-my-first-but-also-last-extech/http://mrmodemhead.com/blog/gallery/craftsman-82003/3) It looks like Bussmann's new color scheme for their fuses is finally making it into all new multimeters made in 2015.
http://www.cooperindustries.com/content/public/en/bussmann/electrical/resources/product_information/fuses-made-simple-control-circuits.html4) Note many tool manufacturers like Klein, Southwire, Craftsman, Snap-On, Mastercraft, Greenlee, Ideal etc do NOT make test equipment. Instead, they rebrand and resell multimeters typically made by others internally unmodified. Even "big name" test and equipment companies like BK Precision, Amprobe and Extech do NOT make their own equipment and simply rebrand and resell like the tool manufacturers.
5) The "baby Fluke" you refer to in your videos is the Fluke 101.
6) Most lower end Extech multimeters are rebranded CEM Instruments meters (same with Southwire). The tall exaggerated slanted LCD digits is a typical sign of the CEM.
http://www.cem-instruments.com/en/pro/sort7-1.html7) Can you provide clear focused high resolution pictures of each multimeter (both sides of the pcb)?
8] With the insulated bodge wire on the V/ohm jack in the Southwire, it looks to be tucked underneath the 10A current shunt. If the meter is measuring 10A current for a prolonged period of time, how will that insulated bodge wire behave?
