Author Topic: Advantest R3132 Spectrum Analyzer ---- RF fail ----  (Read 1219 times)
Offline Freddy2021Topic starter
« on: February 15, 2021, 05:50:50 pm »
Hello people,
I'm new here.
I hope I can get help here.
I have a problem with my ADVANTEST R3132 Spectrum Analyzer (no options),
I bought the device used.
The device worked perfectly so far, except for the error when booting BACK UP RAM == NG
Not OK. and CPU fail (self-test), everything else was fine so far.
Today I replaced the BACK UP battery and now BACK UP RAM is O.K. and during the self-test
(Shift 0) CPU O.K. but the device now shows "RF fail" during the self-test.
Does anyone know what could be defective?
Please help
Thank you in advance
Freddy2021
Offline Grandchuck
Re: Advantest R3132 Spectrum Analyzer ---- RF fail ----
« Reply #1 on: February 16, 2021, 01:54:48 pm »
Does it have a self-calibration function?  If so, have you tried it?
« Reply #2 on: February 16, 2021, 05:30:59 pm »
Yes it does, the problem seems to be thermal.
If the device is cold, everything works, Cal O.K, Self-test O.K
As soon as the device is warm, the - RF Fail-  error occurs during the self-test.
Problem is the RF module ???
Circuit diagram ?
Online nctnico
« Reply #3 on: February 17, 2021, 09:53:35 pm »
Did you already search the forum? I think there are other threads about this problem for the R3132
« Reply #4 on: February 18, 2021, 10:34:11 am »
Yes, thank you .
I found it in the forum, there a similar problem is discussed
Is it also a temperature problem? Could be?
