Hello. I have a multimeter that is doing something new to me. It has a slow auto range and it displays all zero's as it goes through the ranges. It works like this: lets say you are measuring 9vdc, and because it is a 6000 counts, it has to move to the nearest scale to 9v volts, so it will display 0.000 then 0.00 then it will display the readings without shooting high or low. I never saw this on other meters that I own. So if anyone can explain it to me I thank you very much. It's a new meter, replaced batteries and checked with different voltages DC with same results. Thank you for your help.
Joe
