Author Topic: Agilent DSOX3054A not booting possible NAND corruption HELP! (RESOLVED)  (Read 11347 times)
Offline dimmog
    • 34401A Facebook group
Re: Agilent DSOX3054A not booting possible NAND corruption HELP! (RESOLVED)
« Reply #50 on: March 29, 2024, 04:32:18 am »
I have the same errors. Did you manage to fix this issue?
Fixed. The scope was originally with ver 2.10 and I tried to resurrect it with ver 2.35 which in this case was incompatible.
Then I prepared a flash drive with the 2.20 version and it worked immediately. One more DSOX3034A saved  :)
Offline elemenoh
« Reply #51 on: August 16, 2024, 10:03:06 pm »
I had the same issue in another thread. I had been trying to flash with 02.35 firmware. The solution in my case was to flash with older 02.10 firmware which successfully booted the scope. It was then able to update to a current fw. Hope that helps you.
Credit to TheSteve for offering that good advice in my thread.
