For those of you using Windows for Magic USB creation, I wrote a simple step-by-step guide for it.
I personally don't own a DP832 yet, but planning on it.
Windows Magic Drive creation1. Open up your diskpart.exe in Administrative mode
2. Select the disk number of your USB drive.
3. Type
clean all and wait.
- This should take some time, since it is writing zeroes to the blocks.
4. Make partition by typing
create partition primary size=1024.
- The smaller the size, faster the image dump and writing.
- But keep in mind that the sector
0x58E0 should be included.
5. Finally format the partition by
format fs=FAT32 QUICK6. Dump the USB using any kind of tools, output is binary file.
7. Using HxD or other editor, change the data.
- If you are not sure which offset should have the *Magic* numbers, the offset should be
0xB1C000 for FAT32.
- The sector is 0x58E0, which in decimals 22,752th sector.
8. Save the image file to a certain location.
9. Now write the image to the disk using Rufus or BalenaEtcher, etc.
10. Done!
11.
https://www.eevblog.com/forum/testgear/need-help-hacking-dp832-for-multicolour-option/msg2320485/#msg2320485Side note - I added a 100MB Partitioned Dump binary. This should make things easier by skipping the format and partition creation process.
