Ok, 1-2 weeks ago i've modified riglol 1.03d for DG1000Z generation/calculation
here is a full source code:
char version[] = "Riglol 1.03d";
char DP832_private_key[] = "5C393C30FACCF4"; //publ: 0x5EC2D25AE85124
char DS2000_private_key[] = "8EEBD4D04C3771"; //publ: 0x8445B2BE29E5C7
char DSA815_private_key[] = "80444DFECE903E"; //publ: 0x691213692D18FA
char DS1000Z_private_key[] = "6F1106DDA994DA"; //publ: 0x58E9F183B924BB
char DG1000Z_private_key[] = "7412E98108CAB0"; //publ: 0x586E719859AF6C
static char* ascii_map;
static const char ascii_map_dg[] = "MNBVCXZASDFGHJKLPUYTREWQ23456789";
static const char ascii_map_[] = "23456789ASDFGHJKLPUYTREWQMNBVCXZ";
char no_private_key[] = "";
** sign the secret message (serial + opts) with the private key
void ecssign(char *serial, char *options, char *privk, char *lic1, char *lic2) {
char prime1[] = "AEBF94CEE3E707";
char prime2[] = "AEBF94D5C6AA71";
char curve_a[] = "2982";
char curve_b[] = "3408";
char point1[] = "7A3E808599A525";
char point2[] = "28BE7FAFD2A052";
int k_offset = 0; // optionally change ecssign starting offset (changes lic1; makes different licenses)
mirsys(800, 16)->IOBASE = 16;
sha sha1;
shs_init(&sha1);
char *ptr = serial;
while(*ptr) shs_process(&sha1, *ptr++);
ptr = options;
char h[20];
shs_hash(&sha1, h);
big hash = mirvar(0);
bytes_to_big(20, h, hash);
big a = mirvar(0);
instr(a, curve_a);
big b = mirvar(0);
instr(b, curve_b);
big p = mirvar(0);
instr(p, prime1);
big q = mirvar(0);
instr(q, prime2);
big Gx = mirvar(0);
instr(Gx, point1);
big Gy = mirvar(0);
instr(Gy, point2);
big d = mirvar(0);
instr(d, privk);
big k = mirvar(0);
big r = mirvar(0);
big s = mirvar(0);
big k1 = mirvar(0);
big zero = mirvar(0);
big f1 = mirvar(17);
big f2 = mirvar(53);
big f3 = mirvar(905461);
big f4 = mirvar(60291817);
incr(k, k_offset, k);
epoint *G = epoint_init();
epoint *kG = epoint_init();
ecurve_init(a, b, p, MR_PROJECTIVE);
epoint_set(Gx, Gy, 0, G);
for(;;) {
incr(k, 1, k);
if(divisible(k, f1) || divisible(k, f2) || divisible(k, f3) || divisible(k, f4))
continue;
ecurve_mult(k, G, kG);
epoint_get(kG, r, r);
divide(r, q, q);
if(mr_compare(r, zero) == 0)
continue;
xgcd(k, q, k1, k1, k1);
mad(d, r, hash, q, q, s);
mad(s, k1, k1, q, q, s);
if(!divisible(s, f1) && !divisible(s, f2) && !divisible(s, f3) && !divisible(s, f4))
break;
cotstr(r, lic1);
cotstr(s, lic2);
** convert string to uppercase chars
char *strtoupper(char *str) {
char *p;
for (p=str; *p; p++)
*p = toupper(*p);
return str;
** prepend a char to a string
char *prepend(char *c, char *str) {
int i;
for (i = strlen(str); i >= 0; i--) {
str[i + 1] = str[i];
str[0] = *c;
return c;
** convert hex-ascii-string to rigol license format
void map_hex_to_rigol(char *io) {
unsigned long long b = 0;
int i = 0;
char map[] = {
'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H',
'J', 'K', 'L', 'M', 'N', 'P', 'Q', 'R',
'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z',
'2', '3', '4', '5', '6', '7', '8', '9'
/* hex2dez */
while (io[i] != '\0') {
if (io[i] >= '0' && io[i] <= '9') {
b = b * 16 + io[i] - '0';
} else if (io[i] >= 'A' && io[i] <= 'F') {
b = b * 16 + io[i] - 'A' + 10;
} else if (io[i] >= 'a' && io[i] <= 'f') {
b = b * 16 + io[i] - 'a' + 10;
i++;
for (i = 3; ; i--) {
io[i] = map[b & 0x1F];
if (i == 0) break;
b >>= 5;
io[4] = '\0';
char *get_version() {
char *v;
v=version;
return v;
void show_help(char *cmd) {
printf("%s\n", get_version());
printf("\n");
printf("Usage: %s <sn> <opts> <privkey>\n", cmd);
printf(" <sn> serial number of device (D............)\n");
printf(" <opts> device options, 4 characters, see below\n");
printf(" <privkey> private key (optional)\n");
printf("\n");
printf("DP832 starting from v1.09 device options:\n");
printf(" first character: F = official, B = trial\n");
printf(" F3PT - Accuracy\n");
printf(" F6PT - Analyzer and Monitor\n");
printf(" F6LT - LAN\n");
printf(" FALT - RS232\n");
printf(" FLLT - Trigger\n");
printf("\n");
printf("DP832 up to v1.06 device options:\n");
printf(" first character: M = official, 5 = trial\n");
printf(" MWSS - Trigger\n");
printf(" MWTB - Accuracy\n");
printf(" MWTC - LAN and RS232\n");
printf(" MWTE - Analyzer and Monitor\n");
printf("\n");
printf("DS1000z device options:\n");
printf(" DSAB - Advanced Triggers\n");
printf(" DSAC - Decoders\n");
printf(" DSAE - 24M Memory\n");
printf(" DSAJ - Recorder\n");
printf(" DSBA - 500uV Vertical\n");
printf("\n");
printf("DG1000z device options:\n");
printf(" JBNE - 16M Memory\n");
printf("\n");
printf("DS2000 device options:\n");
printf(" first character: D = official, V = trial\n");
printf(" DSAE - 56M Memory\n");
printf(" DSAJ - 100MHz\n");
printf(" DSAS - 200MHz\n");
printf(" DSAZ - all options\n");
printf("\n");
printf("DS4000 device options:\n");
printf(" DSHB - RS232 Decoder\n");
printf(" DSHC - SPI Decoder\n");
printf(" DSHE - I2C Decoder\n");
printf(" DSHJ - CAN Decode\n");
printf(" DSHS - FlexRay Decoder\n");
printf(" DSH9 - all options\n");
printf("\n");
printf("DSA815 device options:\n");
printf(" first character: A = official, S = trial\n");
printf(" AAAB - Tracking Generator\n");
printf(" AAAC - Advnced Measurement Kit\n");
printf(" AAAD - 10Hz RBW\n");
printf(" AAAE - EMI/Quasi Peak\n");
printf(" AAAF - VSWR\n");
printf("\n");
printf("MAKE SURE YOUR FIRMWARE IS UP TO DATE BEFORE APPLYING ANY KEYS\n");
static int ascii_to_bin(char c)
int i;
for (i = 0; i < 0x20; i++)
if (ascii_map[i] == c)
break;
return i;
static char *options_4to5(const char *opt4, char *opt5)
int map[] = { 0, 3, 2, 1 };
int i, opt = 0;
for (i = 0; i < 4; i++)
opt = (opt << 5) | ascii_to_bin(opt4[map[i]]);
for (i = 0; i < 5; i++) {
opt5[i] = ascii_map[opt & 0x0F];
opt >>= 4;
opt5[i] = 0;
return opt5;
static void format_license_dp832_109(char *lic1_code, char *lic2_code,
char *options, char *licence, int isDG)
const int map1dp[] = { 4, 11, 16, 23, 0, 24, 6, 22, 8, 20, 18, 25 };
const int map2dp[] = { 3, 14, 19, 9, 26, 5, 1, 10, 12, 13, 15, 21 };
const int map3dp[] = { 2, 7, 17, 27 };
const int map1dg[] = {3, 0xE, 0x13, 9, 0x1A, 5, 7, 0x11, 0xC, 0x18, 6, 0x16};
const int map2dg[] = {4, 0xB, 0x10, 0x17, 0, 8, 0x14, 0x1B, 2, 0xD, 0xF, 0x15};
const int map3dg[] = {1, 0xA, 0x12, 0x19};
const int *map1 = isDG?map1dg:map1dp;
const int *map2 = isDG?map2dg:map2dp;
const int *map3 = isDG?map3dg:map3dp;
unsigned long long k;
int i;
k = strtoll(lic1_code, NULL, 16);
for (i = 0; k < (1ULL << 51); i++)
k = (k << 4) | 0;
k = (k << 4) | i;
for (i = 0; i < 12; i++) {
licence[map1[i]] = ascii_map[k & 0x1F];
k >>= 5;
k = strtoll(lic2_code, NULL, 16);
k = (k << 4) | 5;
k = (k << 4) | i;
licence[map2[i]] = ascii_map[k & 0x1F];
k >>= 5;
if (isDG) {
char *opt = strdup(options);
opt[i] = options[map[i]];
licence[map3[i]] = opt[3 - i];
free(opt);
else
licence[map3[i]] = options[i];
licence[28] = 0;
static void format_license_classic(char *lic1_code, char *lic2_code,
char *options, char *licence)
char *lic_all, *chunk, *temp;
int i, j;
/* fix missing zeroes */
while (strlen(lic1_code) < 14) {
prepend("0", lic1_code);
while (strlen(lic2_code) < 14) {
prepend("0", lic2_code);
/* combine lic1 and lic2 */
lic_all = (char*)calloc(128, 1);
temp = (char*)calloc(128, 1);
chunk = (char*)calloc(6, 1);
strcpy(lic_all, lic1_code);
strcat(lic_all, "0");
strcat(lic_all, lic2_code);
/* generate serial */
i=0;
while (i < strlen(lic_all)) {
memcpy(chunk, lic_all + i, 5);
map_hex_to_rigol(chunk);
strcat(temp, chunk);
i = i + 5;
/* add options and "-" */
j = 0;
for(i = 0; i <= strlen(temp); ) {
switch(j) {
case 1: licence[j] = options[0]; break;
case 7: licence[j] = '-'; break;
case 10: licence[j] = options[1]; break;
case 15: licence[j] = '-'; break;
case 19: licence[j] = options[2]; break;
case 23: licence[j] = '-'; break;
case 28: licence[j] = options[3]; break;
default: licence[j] = temp[i];
i++;
j++;
licence[j] = '\0';
/* cleen up */
free(lic_all);
free(chunk);
free(temp);
char *make_licence(char *serial, char *options, char* priv_key)
char options_buffer[8], *opts = options;
char *lic1_code, *lic2_code, *lic_all;
char *chunk, *temp, *licence;
int i, j;
/* convert string to uppercase chars */
strtoupper(serial);
strtoupper(options);
strtoupper(priv_key);
int isDG = strncmp(serial, "DG1", 3)?0:1;
/* convert options string format for DP832 with firmware >= 1.09 or for DG1000Z*/
if ((!strncmp(serial, "DP8", 3) && options[0] != 'M' && options[0] != '5') || isDG)
opts = options_4to5(options, options_buffer);
/* sign the message */
lic1_code = (char*)calloc(64, 1);
lic2_code = (char*)calloc(64, 1);
ecssign(serial, opts, priv_key, lic1_code, lic2_code);
/* format licence string */
licence = (char*)calloc(128, 1);
if ((!strncmp(serial, "DP8", 3) && *options != 'M' && *options != '5') || isDG)
format_license_dp832_109(lic1_code, lic2_code, options, licence, isDG);
else
format_license_classic(lic1_code, lic2_code, options, licence);
/* cleen up */
free(lic1_code);
free(lic2_code);
return licence;
char *select_priv_key(char *serial) {
char *priv_key;
strtoupper(serial);
if (!strncmp(serial, "DS1", 3)) priv_key = DS1000Z_private_key;
else if (!strncmp(serial, "DS2", 3)) priv_key = DS2000_private_key;
else if (!strncmp(serial, "DS4", 3)) priv_key = DS2000_private_key;
else if (!strncmp(serial, "DSA", 3)) priv_key = DSA815_private_key;
else if (!strncmp(serial, "DP8", 3)) priv_key = DP832_private_key;
else if (!strncmp(serial, "DG1", 3)) priv_key = DG1000Z_private_key;
else priv_key = no_private_key;
return priv_key;
int main(int argc, char *argv[0]) {
char *serial, *options, *priv_key, *licence;
/* parse input */
if (!((argc == 3 || argc == 4))) {
show_help(argv[0]);
exit(1);
serial = argv[1];
options = argv[2];
ascii_map = strncmp(serial, "DG1", 3)?(char*)ascii_map_:(char*)ascii_map_dg;
if (argc == 4) priv_key = argv[3];
else {
priv_key = select_priv_key(serial);
if (strlen(priv_key) == 0) {
show_help(argv[0]);
printf("\nERROR: UNKNOW DEVICE WITHOUT PRIVATKEY\n");
exit(1);
if (strlen(priv_key) != 14) {
show_help(argv[0]);
printf("\nERROR: INVALID PRIVATE KEY LENGTH\n");
exit(1);
if (strlen(serial) < 13) {
show_help(argv[0]);
printf("\nERROR: INVALID SERIAL LENGTH\n");
exit(1);
if (strlen(options) != 4) {
show_help(argv[0]);
printf("\nERROR: INVALID OPTIONS LENGTH\n");
exit(1);
licence = make_licence(serial, options, priv_key);
printf("%s\n", licence);
free(licence);
Edit: I've added missing line to the function ecssign
