Couldn't find the info in the DP800 User Manual, it say to contact Rigol.
What is the password and the procedure for DP800 manual calibration, please?
I took a quick look at a DG1032Z firmware I found somewhere. I think it's version 1.06. It has a very similar check for the same magic value at sector 0x78EC.
Could someone eager to hack (or brick) their DG1032Z send these commands to it, preferably via USB, and post the results here? The keyfile.bin I made for DP832 should work.
:PROJ:STAT MCALTIMES,QUERY
*IDN?
:PROJ:STAT MODEL,DG1062Z
*IDN?
I think it's better to not mess with:
Just do the:
And you'll have a new model!
has anybody tried this on the scopes?
on the ds1000z series, it may be usefull in the future to switch it to the MSO variant.
also, although i'm not sure, it was the case that Riglol didnt work on the 2000 and 4000 series.
I searched the net and all I could find was something from this thread on page 7 that has been edited or is missing from some other reason. Google Cache was no help.
Out of curiosity, what does the :PROJ:STAT MCALTIMES,QUERY command do? I searched the net and all I could find was something from this thread on page 7 that has been edited or is missing from some other reason. Google Cache was no help.
Does it query calibration times? What's the M for I wonder? Also, why would that command be a bad idea to run?
With the public key 586E719859AF6C you might upgrade riglol and generate the official license for Arb16M.
Doesn't it requrie additional research for obtaining option code(s) from firmware?
I think the interfaces are optional for the DP811, same as DP832?
...I wonder if the random reboots that DP832 owners suffer from for absolutely no rhyme or reason will vanish when software converting to a DP832A...
With the public key 586E719859AF6C you might upgrade riglol and generate the official license for Arb16M.Doesn't it requrie additional research for obtaining option code(s) from firmware?
= riglol 1.03d
