unfortunately These mobility chargers don't have direct access to the sense wires .
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
I can read the voltages before and on the sense connections just behind the relay. The controller panel is mounted vertical . Horrible design for service . to replace parts in the output stage the relay has to be removed .
My Old Array 3710A is the old version which goes to 200w @ 30A but it only has Watts , Resistance & Amps .
I do have a bigger 500w load which I made the control is a bit ruff and jumps up to 30A to fast. waiting for parts to fix.
These chargers are made only to charge Deep cycle acid or gel batteries . Regular car type accumulators the sense circuit ignores them and wont charge.
one of the charges has program chip on the board with one time programing as far as I can figure . That one works and I going to return that back to the user
as is . The one that is causing a problem is over charging by 2.5 volts and not sensing until the battery is below 20v which is too low .
and to make life easy the controller board the chip numbers have been erased .
The resistor in a bucket is not a bad idea . Other than large amount of water and electric maybe more fun
![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
I really prefer working on standard chargers they are so much easier .
I may have to put some jumpers on the sense circuit as suggested that maybe a good work round . Thanks
