Author Topic: Nano VNA like sand on the sea- Who is the "good one" ?  (Read 1828 times)
Online Martin72Topic starter
  • Testfield Technician
« on: July 09, 2024, 09:17:07 pm »
Hi folks,
Quick question:
I just want to play around with a VNA and a cheap Nano VNA seems to be the perfect solution.
However, if you search for it, there are countless variants.
Which one is the "good" one, which one should I get?
Thanks in advance.
Martin
(Kierkegaard)
Online Aldo22
Re: Nano VNA like sand on the sea- Who is the "good one" ?
« Reply #1 on: July 09, 2024, 10:24:32 pm »
There are different screen sizes and bandwidths etc.
I don't know if there is the one "good one".
I have one of the cheapest (as always) from the "SeeSii Factory Store Store" which seems trustworthy/recommended: a NanoVNA-H.
It has an SD card slot, the inputs are shielded, you can update the firmware from the usual sources and I got a pretty big battery (1300mAh), but don't know if that's standard.
It's good enough for me.
More expensive ones are probably better if you have a use for them.
Online tszaboo
« Reply #2 on: July 09, 2024, 10:31:16 pm »
For the Nano, the H4 is recommended by a lot of people. I just bought a LiteVNA, which is a bit faster than the Nanos.
What is even more important is to buy it from reputable sources. Because there are a lot of interior clones out there. They might be missing the shielding. Or the PCB is not impedance controlled. Or the cal kit which comes with it is trash.
The following users thanked this post: egonotto, Martin72
Offline Geoff-AU
« Reply #3 on: July 10, 2024, 12:36:26 am »
This is the most important factor.  Buy a genuine one.
Online joeqsmith
« Reply #4 on: July 10, 2024, 01:26:17 am »
Hi folks,
Quick question:
Thanks in advance.
Martin
As you said, they are cheap, and if you just want to play, I don't think it really matters too much.  Later as you refine your requirements, you can always buy something that better fits.
I continue to use the LiteVNA64 for some experiments.   We purchased ours from:
https://www2.randl.com/index.php?main_page=product_info&products_id=75669
Offline BrokenYugo
« Reply #5 on: July 10, 2024, 01:37:57 am »
The following users thanked this post: egonotto, KungFuJosh, teddychn
Online KungFuJosh
  • TEAS is real.
« Reply #6 on: July 10, 2024, 01:45:32 am »
nanovna.com suggests a specific Aliexpress store.
https://nanovna.com/?page_id=121
https://zeenko.aliexpress.com/store/1101394653
That actually makes sense. That's also the official store for the TinySA.
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Offline ch_scr
« Reply #7 on: July 10, 2024, 06:22:38 am »
For Europe/Germany, buying the LiteVNA from Eleshop seems like a reasonable solution.
It depends on usage though, if you want to use it as an LCR meter up to 300MHz the much cheaper ones might even be preferred.
For antenna / filter measurement over a wider range, I'd get the LiteVNA.
The following users thanked this post: egonotto, newbrain, Martin72, Aldo22
Online Aldo22
« Reply #8 on: July 10, 2024, 07:38:47 am »
Yes, but Seesii is also OK and at least the Seesii Amazon store is officially recommended for the tinySA.
I have tinySA and nanoVNA from the Seesii Aliexpress store and both are flawless.
You can also buy directly from Seesii.
Offline woody
« Reply #9 on: July 10, 2024, 09:55:18 am »
+1 for this one. Get the 64.
Online kripton2035
« Reply #10 on: July 10, 2024, 10:00:08 am »
I did not buy one actually, but I narrowed also to the eleshop litevna 64 some times ago ...
Online Aldo22
« Reply #11 on: July 10, 2024, 10:13:37 am »
It's a question of whether you want to spend around €50 or around €200.
More expensive is usually better. The question is what you need and whether the extra cost is worth it for you.
I don't really need to ask the forum for the tip: "buy the most expensive one".  ;)
Offline ch_scr
« Reply #12 on: July 10, 2024, 10:43:28 am »
It's a question of frequency range. Up to 300MHz -> 50€; Up to 6GHz -> 200€.
Online Aldo22
« Reply #13 on: July 10, 2024, 10:53:27 am »
Sure, that too, but doesn't the 50€ version go to 1.5GHz?
If you know that you need 6GHz, then buy the 6GHz version.
« Last Edit: July 10, 2024, 10:56:25 am by Aldo22 »
Online tszaboo
« Reply #14 on: July 10, 2024, 11:30:13 am »
Indeed, the model depends what you are trying to do.
Bacon radio or ham radio, 300 MHz is plenty.
Sub-GHz radio, test equipment like oscilloscope probes, coax cables, then the 1.5 GHz model is recommended.
More modern digital radio interfaces work in the~3 GHz bandwidth, so the 6GHz LiteVNA model makes sense. It's 4x the frequency for 4x the price, which is a very good deal. To put it in perspective, I paid more just for a calibration kit for a "proper" VNA in the past.
And while these units are not going to give the same dynamic range (decibels) as standalone units, 30dB of noise free range is plenty for anything antenna related.
Offline ch_scr
« Reply #15 on: July 10, 2024, 11:43:51 am »
"The 50K-300MHz-Range has a dynamic range of more than 70 dB. The extended 300M-900MHz-range has more than 60 dB and 900M-1,5-GHz more than 40 dB"
As usual "it depends" but above 900MHz you'll really want the "better" one.
« Reply #16 on: July 10, 2024, 11:45:48 am »
Hello,
Thank you for the numerous replies. :-+
What I was able to filter out for myself is that there is such a thing as "authorized" distributors.
And it also sounds good that you can use the smaller, cheaper ones for LCR measurements, because that's what I'm interested in.
However, I find the "larger" screen to be quite small, so the 2.8" models are a no-go.
On the Nano VNA page, AURSINC is mentioned as an amazon dealer, which would be this device, for example:
Nano VNA-F V2
That would be OK then?
(Kierkegaard)
Offline ch_scr
« Reply #17 on: July 10, 2024, 11:52:38 am »
Hello,
Nano VNA-F V2
I don't get the appeal? For like 5-10€ more you get the 6GHz LiteVNA already, and from a proper distributor. It comes with cables and cal standards as well.
Online Aldo22
« Reply #18 on: July 10, 2024, 12:07:50 pm »
That's a matter of taste.
The 2.8" model fits easily in your pocket and if you need it more convenient, there is the PC software.
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #19 on: July 10, 2024, 12:08:24 pm »
I have a "vintage" NanoVNA and an H4.  The H4 is much nicer, and I can do a FW swap to turn it into a phase and frequency analyzer.
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline pdenisowski
« Reply #20 on: July 10, 2024, 12:12:22 pm »
If I'm putting my NanoVNA in my pocket (so to speak), I'm probably using it outdoors to do things like antenna and cable testing, and this is where a larger unit, better controls, and a nicer screen make a big difference.  I would gladly buy yet another NanoVNA if someone would package it with better controls and a much larger/brighter screen.
« Reply #21 on: July 10, 2024, 12:23:08 pm »
The 2.8" model fits easily in your pocket and if you need it more convenient, there is the PC software.[/quote
Some of the models are dramatically cheaper and that can't just be down to the smaller screen, can it?
(Kierkegaard)
Online Aldo22
« Reply #22 on: July 10, 2024, 12:33:17 pm »
That sounds like the 50€ version to me.  ;)
If you need more range/bandwidth or a bigger screen, then compare the specs and buy the one that fits.
I already said that in my first answer:
More is usually better... and more expensive.
Offline bingo600
« Reply #23 on: July 10, 2024, 12:47:49 pm »
Martin i'd buy from eleshop.eu or eleshop.nl (eu shows prices wo VAT) - eleshop is authorized reseller.
I'd also get a litevna64, if you need to play with freq's over 300MHz
https://www.eleshop.nl/litevna-64.html
Or you could start with a H4' , if Freq under 300MHz - But "Murphy" says in 2 weeks you want to check your 433MHz or WiFi antenna ....
https://www.eleshop.nl/nanovna-h4.html
But if you go cheap (H4) - Then once you grow out of your H4' , and get a litevna64  ;)
You can reprogram the H4 as a TinyPFA , and play w. phase analysis of Xtals or GPSDO's
Don't get the NanovnaH - The F072 MCU is too weak.
I have a H4, a litevna64 , a V2Plus4  - But usually reach for the litevna64.
I also have the TinySA Ultra - Cute little tool at the right price.
Ps: The litevna64 battery draining issue that i have, should be fixed in the newer verions.
/Bingo
« Last Edit: July 10, 2024, 01:04:57 pm by bingo600 »
The following users thanked this post: egonotto, newbrain, ch_scr, Martin72
Online joeqsmith
« Reply #24 on: July 10, 2024, 12:50:14 pm »
Its not just a matter of upper frequency.  The LiteVNA's narrow band performance is really poor.  The original NanoVNA will far out perform it in that case.   If you attempt to measure power distribution networks, again the original NanoVNA will out perform the Lite.  They are so cheap, you can spend $250 and have both.
I am not aware of any 1.5GHz units.  You can certainly use harmonic with the original NanoVNA / H4 that will allow you work up that high but the performance is really poor.  Not to mention other problems it can cause.
I always use the PC so the screen size and other options really are not important.   That said, the original NanoVNA & H4 use a different protocol than the LiteVNA.   If using them with a PC is important, make sure that what ever software you plan to use supports the VNA (before you buy).
Should mention that the LiteVNA64 also supports harmonics.   Attached comparing the floor of my LiteVNA64 compared with my Agilent PNA.   You can operate the LiteVNA64 even higher but as you can see, the performance is poor.
Also, people will ask if their XXXXXXX brand/name cheap VNA will work with my software.  I have a version that supports the older protocol.  The firmware installed in these makes a big difference on how stable they are.  I abandoned that project some time ago and now only support the LiteVNA64.   There is also the V2Plus4 that supports the newer protocol.  It will work with my software but because the firmware, it has fallen far behind.  I have not used mine since I bought the LiteVNA64.
The LiteVNA64 also has a new version of hardware.  This new version improves the dynamic range a small amount but also appears to have a problem where the frequency is not stable.   It doesn't appear to be firmware related but rather the hardware.  The frequency seems to dip 50Hz from time to time.  Both of my older revisions to not exhibit this problem.  Just something to be aware of.
« Last Edit: July 10, 2024, 01:08:02 pm by joeqsmith »
The following users thanked this post: bingo600, egonotto, DaneLaw, Martin72
