Author Topic: SIGLENT 3045 Remote EasyDMM Logging Issue?  (Read 126 times)
Offline sbeckertTopic starter
« on: July 21, 2024, 05:12:55 pm »
Wondering if anyone else has seen this remote logging issue using EasyDMM s/w?
When collecting remote measurements using EasyDMM (USB or LAN) I've found that Manual sample rate settings (tried fast to very slow) return duplicate readings about every 5-15 readings. The time increment increases normally but the reading is idential to the previous reading. When I go to Auto mode, which samples about 5sa/sec, the problem seems to disappear.
I've attached a pix what a clean sine wave input to the DMM produces when using Manual sampling in EasyDMM.
Anyone else seen this?
Thanks - Scott
« Last Edit: July 21, 2024, 05:15:27 pm by sbeckert »
Offline KungFuJosh
  • TEAS is real.
Re: SIGLENT 3045 Remote EasyDMM Logging Issue?
« Reply #1 on: July 21, 2024, 06:02:47 pm »
I don't like EasyDMM. You should check out TestController which is free and made by a member of this site. https://lygte-info.dk/project/TestControllerIntro%20UK.html
There's a small learning curve, but it's far superior to EasyDMM.
« Reply #2 on: July 21, 2024, 09:51:32 pm »
Thanks - I'll take a look at it. Scott
