I just watched the tear down video, thanks, and compared with the WD-1 station I have. Without going into detail it absolutely confirms my impression. The JBC has too many ribbon cables (bad design), the plastic is very cheap and I can see twisted workmanship (board not aligned evenly too case and such). Or the use of rubber membrane switches… compared to micro switches in the Weller. ![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
You didn't actually answer my question though (hand tools, ....).
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
FWIW, I also own a Weller WD1 (+ WMP, WSP80, & WDH10T), and they're not perfect either. The LT series tips made in Bosnia have been of particular issue, but the issues affect their brand overall (Germany, Bosnia, and Mexico for example; precious little Weller made in the US anymore). If you check the WRM3 repair link and scroll down, there's photos of the innards of my WD1 you can compare to
Balizoft's and yours (date codes floated between the 38 & 40th weeks of 2006 on mine). Definitely cost cutting going on in mine.
Regarding not going into details as you perceive them on the JBC (or any other device/tool), this is EEVBlog. Which means such detail is expected (unwritten rule).
![Evil >:D](https://www.eevblog.com/forum/Smileys/default/evil.gif)
On a quick comparison, I see them as follows:
- As per rubber membrane buttons, they can be capable of a high number of cycles if made well IME (i.e. remote controls). Conversely, micro switches can be made to be as cheap as possible, severely shortening their lifespan. I'd give a slight edge to the Weller on the basis they're easier to replace than repair the membrane (assuming there aren't any spares from JBC, so repair would be more involved).
- In regard to the ribbon cables, there's only 2 I'd be concerned about (non-display related), which is the same number if you've the USB board installed (WD1M). Only difference is termination (JBC terminates to solder pins, while Weller uses connectors <IDC male & soldered PCB female>), but I don't really see that as an issue. Overall, I'd say a toss up really.
- I do prefer the cast aluminum base to the Weller vs. a plastic base, but it's not the end of the world. It's not the only JBC design out there (have seen metal base plates in separate power units before), so this may be model dependent. Plastic on the Weller is meh IMHO, but it does it's job I guess (afraid the retention tabs will snap off, but I'd only need cross that bridge when it happens).
- Regarding the misaligned board, I'm not quite sure of what you're seeing.
The JBC isn't perfect, but it's by no means an epic fail either. Same goes for the WD1. And either will make decent joints.
But between them, the JBC is a better performer. It also has the edge on tips (more profiles available, and the plating thickness is consistent).
The WX series gets very close to JBC performance wise, but you'll pay handsomely for it (
WX1010; best street price I'm aware of before any further discounts). Most street prices are running ~$520 for this particular kit, putting it on par with the separate power unit & tool based models from JBC on price.
