Author Topic: My Keithley DMM7510 is screwed up detecting mains line frequency!  (Read 2673 times)
Offline DragonyTopic starter
Hello,
I have just purchased a DMM7510 but although most parts of it seems to work fine I have encountered a major problem with line frequency.
I live in Switzerland and we have 50Hz.
The problem is that the DMM sometimes detects 50Hz and sometimes 60Hz. Keithley decided not to allow the user to change this setting manually.
Furthermore, when I click on "Line Sync" when measuring DC Voltage (Settings dialog, well hidden), the DMM crashes everytime. (Can someone confirm this?)
Does someone has the same problems and has a hint how to work around this issues?
Offline TAMHAN
  • Country: sk
Re: My Keithley DMM7510 is screwed up detecting mains line frequency!
« Reply #1 on: March 01, 2017, 08:39:48 pm »
Dragony, first of all, I do not own this unit. But, reading EEVblog and also electronics and arms electronics sources quite a lot, I have not heard much good about Danahers Keithley DMM family. I can recall crashes everywhere, and them generally being finicky.
Plus, Danahers repair fees become ANAL the moment you are out of warranty. If I were you, I would try my luck at chucking the thing back at Danaher and grabbing a different meter.
Feel like some additional tamile wisdom? Visit my YouTube channel -> https://www.youtube.com/user/MrTamhan for 10min tid-bits!
Offline The Soulman
  • The sky is the limit!
« Reply #2 on: March 01, 2017, 08:47:07 pm »
If purchased new send it in under warranty.
If second hand..  :-//
« Reply #3 on: March 01, 2017, 08:49:18 pm »
I tested this with my DMM 7510 and it does not crash. Firmware version is 1.6.1a
Offline technogeeky
  • Older New "New Player" Player Playa'
« Reply #4 on: March 01, 2017, 08:52:34 pm »
I'm a little confused about this. Are the units sold by Danahers different than the regular Keithley units? I hold Keithley to be world class, and DMM7510 to be similarly so.
Offline VintageNut
« Reply #5 on: March 02, 2017, 06:47:07 am »
Hello,
I have two suggestions for  you.
1. Post on Tek/Keithley forum asking for help
2. Contact Tek/Keithley service group in Germany
working instruments :Keithley 260,261,2750,7708, 2000 (calibrated), 2015, 236, 237, 238, 147, 220,  Rigol DG1032  PAR Model 128 Lock-In amplifier, Fluke 332A, Gen Res 4107 KVD, 4107D KVD, Fluke 731B X2 (calibrated), Fluke 5450A (calibrated)
Offline HighVoltage
« Reply #6 on: March 02, 2017, 09:51:14 am »
I had plenty of problems with my Keithley DMM7510.
After the problems were posted on the Tek forum, Keithley got very responsive and fixed many problems in interim FW
Right now I am running FW 1.6.3c and have no problems at all.
Keithley is about to release an official new FW and that should also address your problem.
I tested your problem on my instrument and I do NOT have this problem at 50Hz line frequency in Germany.
« Reply #7 on: March 03, 2017, 02:11:23 pm »
I can't find your topic regarding your problems in the tek forum. Can you provide a link?
Offline TAMHAN
  • Country: sk
« Reply #8 on: March 03, 2017, 03:10:28 pm »
Danaher owns Keithley, Tek and Fluke.
Offline HighVoltage
« Reply #9 on: March 03, 2017, 04:57:55 pm »
Here is where we have discussed our problems with the 7510 on eevblog
https://www.eevblog.com/forum/testgear/keithley-dmm7510-smu-2450-2460-problems/
And here on the Tek forum
https://forum.tek.com/viewtopic.php?f=363&t=139083#p281815
