The FX-888 tips are compatible with the Hakko 936 tips. There's maybe just a few mm difference in the length (in real world, maybe the temperature would get get offset by a few degrees C)These should be original Hakko:https://www.sparkfun.com/products/10721https://www.sparkfun.com/products/10720https://www.sparkfun.com/products/10719This ebay seller (who claims to be authorized Hakko distributor - you can check on Hakko website when it works) has several other models along with the 936 tip code they replace in the title of each listing: http://stores.ebay.com/NEI-Lamps-and-Electronics/HAKKO-SOLDERING-TIPS-/_i.html?_fsub=4&_sid=82105093&_trksid=p4634.c0.m322
Which tips you use depends on the hand piece - there were a few available for the 936. The most common was the 907 which takes 900M series tips, which have been replaced by the T18 series tips used by the FX888 - Hakko doesn't list them as compatible but they are essentially identical and lots of people use them.
T14 tips are for the 938
