Author Topic: Multimeter spreadsheet (80 manufacturers and over 400 meters listed)  (Read 869383 times)
Offline videobruce
Re: Multimeter spreadsheet (80 manufacturers and over 400 meters listed)
« Reply #500 on: November 13, 2020, 01:07:50 am »
To confirm; all of these are 'Autoranging'??
I was looking for non autoranging since I don't like the delay waiting for the meter to do what I already did. And yes, I know the single disadvantage, but in 30 years, I never wiped one out.. ;)
Offline WytnuclsTopic starter
« Reply #501 on: November 13, 2020, 06:05:58 pm »
Yes, as stated in the intro on post one, all meters are autoranging. Most, if not all, also have manual ranging, for some specific applications.
Offline AE7OO
« Reply #502 on: November 27, 2020, 11:55:20 am »
I did not see my favorite meter(Because I got it super cheap last Christmas), the Holdpeak 6688G.
https://holdpeak-store.com/hp-6688g-multimeter-1000v-20a-capacitance-ammeter/
While it has some problems(the continuity beeper is a nightmare), it's hard to approach 40000 counts for around $50.  And since I use it more or less as bench meter, the fact that it's a BRICK, is not down check for me.
« Reply #503 on: November 28, 2020, 05:20:59 am »
Thanks. It will be included in the next revision. Remember that a high count meter without a decent voltage reference will drift eventually. Not impressed with the internal construction. Beware.
The following users thanked this post: AE7OO, Trader
Offline Trader
« Reply #504 on: November 28, 2020, 06:27:46 pm »
I think that table should list only the "best" DMMs
What is best? several specs e.g.: very small long term drift.
Today there are a LOT of DMMs with +50K counts, but in 5 years, how many will keep the calibration?
* Voltcraft VC890 (60,000) # https://www.conrad.com/p/voltcraft-vc890-oled-handheld-multimeter-digital-oled-display-data-logger-cat-iii-1000-v-cat-iv-600-v-display-counts-124600
* Tenma 72-3540 (60,000) # https://uk.farnell.com/tenma/72-3540/dmm-handheld-true-rms-auto-manual/dp/2667186
* Prova 903 (60,000) # https://lygte-info.dk/review/DMMProva%20903%20UK.html
* TPI 194 II (50,000) # https://www.testproductsintl.com/digital-multimeters-dmms/194-digital-multimeter/
* RS PRO HS608 (with oscilloscope) (50,000) # https://uk.rs-online.com/web/p/digital-multimeters/1445337/
* CEM DT-9989 (with oscilloscope) (50,000) # http://www.cem-instruments.com/en/Product/detail/id/889
* CEM DT-9987 (50,000) # http://www.cem-instruments.com/en/Product/detail/id/896
* RuoShui 189A (55,000) # https://www.aliexpress.com/item/1005001483719011.html
The following users thanked this post: MarcosL
Offline AE7OO
« Reply #505 on: December 06, 2020, 07:49:07 am »
Yes, I know that the Holdpeak HP-6688G has problems.  Poor QC is at the top of the list.  As far as the design goes, let's not go there.
As soon as I received it, I popped it open.  I just wish I would have taken photos.
I found 2(TWO OF THEM!?!  :wtf:) tombstoned caps right off, which I fixed.
I picked it up CHEAP(about $16 Prime) from Amazon a couple of years ago.
A recent use I put it to recently was when I started gathering the materials to make one of Conrad's Kelvin-Varley Dividers.  Instead of building one of the bridge circuits to sort the various resistors I just used the meter after making a simple fixture to easily change the resistors out.  For things like this, it works just fine.
Offline LeonR
  • Country: br
  • PC hardware enthusiast
« Reply #506 on: December 07, 2020, 03:55:14 pm »
I've been wondering for some time now: Does any of the Chinese OEM use feedback given on electronics forums like this to improve/fix stuff in their meters?
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #507 on: December 07, 2020, 04:23:23 pm »
Probably yes, given that I have seen a lot of marketing sentences and design changes reflecting what is commonly said around here - things such as ceramic fuses, demonstration of protection in all ranges, etc. It is basically free consulting services for anyone in the business.
« Reply #508 on: December 11, 2020, 06:06:14 pm »
Having spent a fair amount of time in China, I doubt very much manufacturers spend any time following discussions on electronics forums.
First of all, few people understand English and YouTube videos are not readily accessible.
With few exceptions, companies cater mostly for the local market and local regulations.
They may sometime be influenced by requests from large retailers from India, for instance.
The following users thanked this post: Trader
Online HKJ
    • Tests
« Reply #509 on: December 11, 2020, 06:51:29 pm »
I do not know if they follow youtube, but I (my reviews and direct communication) have been the reason for some changes in battery chargers.
The following users thanked this post: rsjsouza
« Reply #510 on: December 11, 2020, 08:59:48 pm »
Have you had similar experiences with multimeter manufacturers?
Where in China was the product from?
« Last Edit: December 11, 2020, 09:10:39 pm by Wytnucls »
Online HKJ
    • Tests
« Reply #511 on: December 11, 2020, 09:27:19 pm »
No, but then I have never received a multimeter for review, all my DMM reviews are done on meters I bought. With chargers some manufactures often send me one for review.
I do not remember the locations, but probably Shenzhen (I do not want to specify any brand names).
Offline wally2q
« Reply #512 on: March 04, 2021, 12:28:26 am »
Good table - first time I noticed it.
I noticed one of the columns are labelled mF... right next to pF.
I know pF is picoFarads, so is mF meant to represent miliFarads on the capacitor measurement scale?...
if so, miliFarads is not a common order of capacitance values.
As you know, there are
pF = picoFarads
nF = nanoFarads
uF = microFarads
and then for values larger than microfarads, they either show a value of 1000uF or 10000uF for 1miliFarads or 10miliFarads.
Sometimes, supercaps then use Farads by themselves.
But I have never in my 30years of electrical engineering, came across a miliFarad unit used on a meter, or on a capacitor.
I have seen some capacitors incorrectly labelled as miliFarads (mF), where the actual value was teh same but in microFarads.
cheers!
Offline tautech
« Reply #513 on: March 04, 2021, 12:51:40 am »
Typo I'd bet as m is next to n on a keyboard.
Online rsjsouza
  • Eternally curious
« Reply #514 on: March 04, 2021, 03:38:24 am »
No, it's not a typo. Given the table already is very cramped, the "mF" is the maximum capaacitance measurement in milifarads or thousands of microfarads.
To be honest, nowadays a very broad range of DMMs that measure large capacitances (larger that 10000uF) tend to use mF in the annunciator. I have seen models from Keysight, Uni-T, Aneng, Richmeters, Sanwa and others.
The following users thanked this post: I wanted a rude username
« Reply #515 on: March 04, 2021, 06:11:03 am »
While traditionally caps are not marked in mF (possibly to avoid confusion with nF), it is still a valid SI unit and used liberally in documentation.
Here is a Vishay example:
« Reply #516 on: March 04, 2021, 06:35:44 am »
Offline tautech
« Reply #517 on: March 04, 2021, 07:15:15 am »
So therefore so it is plainly clear you've used mF, correct ?
« Reply #518 on: March 04, 2021, 07:52:37 am »
Of course. I need to keep the columns as narrow as possible.
Offline wally2q
« Reply #519 on: March 04, 2021, 06:29:37 pm »
OK cool.... it was intentional... and yes it is an SI unit....
so as unusual as I may find it - i'm good.
On the Vishay cap table example - some were listed in mF and some in uF... ex 10000uf in one line... and 1.8mF in another -> why not just converge on a single unit - say 1800uF, instead of 1.8mF..... or 10mF instead of 10000uF... ??    :palm:
Oh well...
The following users thanked this post: Wytnucls
« Reply #520 on: March 07, 2021, 10:06:25 am »
Most current spreadsheet with the latest multimeters added and some housekeeping.
The following users thanked this post: hammy, J-R
Offline Analog4
« Reply #521 on: March 08, 2021, 10:37:14 pm »
Thanks for the update!
I see it now includes the Bryman BM789, which only has 20k BW compared to 100k BW for the Bryman BM869 & Greenlee DM-860A. I prefer the 100k BW & had been thinking about the Bryman BM789, but now more seriously considering the Greenlee DM-860A for the USA warranty.    :clap:
Offline vutt
  • Country: ee
« Reply #522 on: March 10, 2021, 07:38:04 pm »
Hm I think there must be some mistake with Advantest R6551 spec in your .xls
My R6551 looks like this https://www.youtube.com/watch?v=DnozavvCiIU, no VFD, no Frequency counter.
« Reply #523 on: March 10, 2021, 08:34:17 pm »
Thanks. I will correct that in the next revision.
Offline Trader
« Reply #524 on: March 21, 2021, 01:31:53 am »
Brymen BM789, AC Bandwidth is 100kHz (not only 20kHz)
https://static.eleshop.nl/mage/media/downloads/BM780_datasheet.pdf
The following users thanked this post: impetus_maximus
