Author Topic: Multimeter spreadsheet (80 manufacturers and over 400 meters listed)  (Read 855507 times)
Offline dijkmane
Re: Multimeter spreadsheet (38 brands and 210 meters listed)
« Reply #475 on: September 19, 2019, 05:25:15 pm »
well, sorry for that.
but i saw a lot of people asking for updates en giving relevant information and no response from the original author.
thats why i found it ok to let other people update the list.
off course its your hard work and you deserve the credits.!
we'll have to be patient for now
Offline WytnuclsTopic starter
« Reply #476 on: September 19, 2019, 06:30:31 pm »
If anybody wants an unprotected version of the files for their personal use, become an EEVBlog supporter, and I'll forward the files upon request by email.
The following users thanked this post: EEVblog, electricMN, sylvandb, Trader
Offline ofalltrades
« Reply #477 on: January 26, 2020, 04:36:43 pm »
It looks like the ABCs if DMMs link is outdated. Looks like it was referring to this, so here is an updated link: https://dam-assets.fluke.com/s3fs-public/1260898_0000_ENG_P_W.PDF
The following users thanked this post: Wytnucls
Offline Mattheprofessional
  • Country: in
  • Hardware Engineer by Profession
« Reply #478 on: February 05, 2020, 05:52:44 am »
Really appreciate the effort that you have taken to write this kind of comparison.
"Sharing is Caring"
« Reply #479 on: February 06, 2020, 06:36:06 pm »
All links have been updated
Thanks for the heads up.
Offline TnF
  • Country: cy
« Reply #480 on: February 27, 2020, 12:46:11 am »
Are the Eevblog meters missing from the list or i'm just blind?!?
« Reply #481 on: February 27, 2020, 08:28:31 am »
Follow the links on page 1 for the full database:
Here are the links for the most recent files (09May17):
Handheld meters   https://www.eevblog.com/forum/testgear/multimeter-spreadsheet/?action=dlattach;attach=315135
Bench meters   https://www.eevblog.com/forum/testgear/multimeter-spreadsheet/?action=dlattach;attach=315136
« Last Edit: May 10, 2020, 11:55:49 am by Wytnucls »
Offline stafil
« Reply #482 on: April 19, 2020, 05:13:03 am »
Shouldn't Fluke 87, 87III, 87V and 185 have the shade of their counts set to amber?
« Last Edit: April 19, 2020, 05:16:48 am by stafil »
« Reply #483 on: April 19, 2020, 01:18:04 pm »
No. Only to acknowledge that a HiRes mode is available.
Offline kawal
« Reply #484 on: April 22, 2020, 01:42:41 pm »
Update for spreadsheet
Keithley 196 which I recently acquired has ZBXO math functions .   The meter table shows it has nothing . This is a true sleeper meter in my opinion.  LED display is awesome.  Takes 2 hours to stabilize to full specs per manual. Current and ACV is 5.5 digits max (which is  not typical for 6.5 digit meters) but has excellent  low current ranges 300uA , 3mA,  30mA, 300mA, 3A!
Also has ohms compensation which is not common . Too bad it has no statistical functions as it would be perfect. Also can be  front panel calibrated and  saves to EEPROM . Each range can be re calibrated separately.
The  HP  3457A has MAND  not MND .  Average (Actually called MEAN on the HP) displays  8 digits and exponent  not sure how many samples can be used but have used recently with 41.3k samples when i stopped the stats function.
« Reply #485 on: April 22, 2020, 07:41:16 pm »
Thanks for the heads-up. Will update the sheet at the next revision.
The following users thanked this post: kawal
Offline kawal
« Reply #486 on: April 23, 2020, 03:04:41 pm »
Awesome list that i reference a lot.  Thanks for maintaining it.
Offline Chris Roubis
  • Chris Roubis
« Reply #487 on: May 10, 2020, 04:44:11 am »
Dam that's a comprehensive list of meters.
Very informative.  :clap:
Fluke 115  :-DMM  :-+
Electricians have longer fuses
Offline tnn85
« Reply #488 on: July 11, 2020, 10:20:34 am »
Wow. This was exactly what i am looking for. Thank you for your great job.
Are there already plans when you will realease the next update? (e.g. product names of Gossen Metrawatt MMs habe changed).
« Reply #489 on: July 12, 2020, 11:49:01 am »
Update coming up shortly. Don't expect many changes. There have been very few new meters since the last upload.
Gossen meters new nomenclature will be updated and the amazing S IM Xtra will be included.
« Last Edit: July 12, 2020, 11:56:27 am by Wytnucls »
The following users thanked this post: tnn85
« Reply #490 on: July 22, 2020, 01:00:34 pm »
Here are the latest multimeter spreadsheets:
The following users thanked this post: lowimpedance, rsjsouza, hammy, coromonadalix, electricMN, Markus2801A, tnn85
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #491 on: July 22, 2020, 07:30:01 pm »
Wytnucls, thank you for this excellent and long awaited update.
A few remarks:
The UT61E goes up to 220mF and 200M\$\Omega\$
Below follows one additional meter that is 6200 counts.
Richmeters 113D
CountAC+BWDUTVoltAccuracyuAnA AccAbwm\$\Omega\$nS/M\$\Omega\$CntpFmFDioHz%WPCKitInt LogClockDispLight'|'''|'M/mPeakHlddBLoZVFDBattLifeF GE PwrJackFuseCATULEMCIPP/F4-20NCVPriceYr
6200x1kx10uV05/-/510u120/-/551k10060Mfast, visual, non-Adj101003.010Mvxvxxxx1White, Flashlightxxxxxxx3AAAxxxx250II 600xxxxxv$15x
« Last Edit: July 22, 2020, 07:31:58 pm by rsjsouza »
« Reply #492 on: July 23, 2020, 08:16:05 am »
Read the column notes at the top of the chart.
If the accuracy is 3% and above, or if there is no accuracy quoted in the manual, the range is disregarded in the database.
There is a note in the cell for the 61E mentioning the top range and its accuracy.
It seems that a new cheap and nasty meter comes out of China every week.
This T21-D from NJTY is no exception.
I will include it in the next update for the sake of completeness.
Offline Trader
Re: Multimeter spreadsheet (60 brand names and over 300 meters listed)
« Reply #493 on: September 01, 2020, 09:28:32 pm »
About counts: I realized that the Fluke 289 is 55000 counts.  I know that is declared 50000 everywhere, but it's measuring 5.5000V.  Some explanation?
Offline HKJ
    • Tests
« Reply #494 on: September 02, 2020, 10:31:27 am »
Some multimeters list a slightly lower count than they have, you can see the real counts here: https://lygte-info.dk/info/DMMReviews.html
The following users thanked this post: Trader
« Reply #495 on: September 22, 2020, 08:51:17 am »
I have put together a PowerPoint presentation about the testing required for a multimeter to conform to the present regulations in the US and Europe.
It is based on multimeter regulations abstracts and Intertek testing documents.
Should you have relevant information that contradicts some aspects of the presentation, please post it here and modifications will be considered.
(Powerpoint slides have been saved as a PDF document because of upload restrictions)
« Last Edit: September 26, 2020, 02:38:21 pm by Wytnucls »
The following users thanked this post: BravoV, rsjsouza, electricMN, Trader
Online rsjsouza
  • Eternally curious
« Reply #496 on: September 24, 2020, 08:51:26 pm »
Wytnucls, u da man. Thanks!
« Reply #497 on: September 26, 2020, 01:52:57 pm »
Here is a PowerPoint presentation I put together about multimeter EMC testing, also saved as a PDF document.
It is based on published regulations and multimeter test reports.
Once again, should you have relevant information that you feel should be included in the document, please post it in this thread.
Offline Tracer
  • Country: in
Re: Multimeter spreadsheet (80 manufacturers and over 400 meters listed)
« Reply #498 on: October 22, 2020, 06:40:39 pm »
...If you feel I have left out some worthwhile DMMs, squawk here and I will try to include them.
All meters listed have a count of 6,000 or higher, have auto-ranging and are true RMS.
All meters (except MetraHit M30) must be able to test diodes, resistance, capacitance, frequency and current.
You will find green highlights for above average features and amber highlights for poor or missing important features...
I just got a Sunshine DT-17N DMM which ticks all of the above.
Appears to combine all the features of both the Thsinde 18B and 19B+ in one model (temperature and NCV functions).
It also uncannily resembles the Thsinde meters in looks.
Manufactured by Guangzhou Sunshine Electronics Technology Co., Ltd. in the People's Republic of China (who BTW also happen to own the Quick rework/soldering station and Relife flux brands):
https://www.exinxun.com/multimeter/ss-dt17n.html
A google search reveals that the DT-17N is quite popular in the value segments of the Asian and Latin American markets.
Unfortunately, the user manual is not available in PDF.
...Edited to add image of specifications printed on the bottom of the box:
« Last Edit: December 11, 2020, 04:11:51 pm by Tracer »
« Reply #499 on: October 22, 2020, 07:43:19 pm »
Thanks. (It will be lumped with the Thsinde 19B+)
« Last Edit: October 23, 2020, 01:51:00 am by Wytnucls »
The following users thanked this post: Tracer
