Author Topic: multimeter probe, tweezers plunger one called  (Read 3390 times)
Offline chefslotTopic starter
« on: February 11, 2018, 06:14:24 pm »
 |O Ok so not the hook type, but a plunger type probe where as you push down two little arms come out to clamp onto a connector pin or something along those lines. The closest i can find are like this, but sold as a kit, i then tried googling some of the words in the description of the product, but no luck. This is like one of those stupid sunday questions but is possible really easy and worth 10 points  :palm:
Offline TimFox
Re: multimeter probe, tweezers plunger one called
« Reply #1 on: February 11, 2018, 06:25:15 pm »
Try "grabber" or "mini grabber" in searching.
The following users thanked this post: chefslot
« Reply #2 on: February 11, 2018, 06:33:41 pm »
Well thank you, i was searching uk only, seems i have to extend my searches to china. But also found these, none of them have pictures of what they are and for the money i thought i might as well buy them to see.
Offline nanofrog
« Reply #3 on: February 11, 2018, 06:48:23 pm »
Pincers is another term used (link).
Offline JDubU
Offline Neomys Sapiens
« Reply #5 on: February 11, 2018, 09:46:37 pm »
The original (full-size) ones from the Hirschmann brand (SKS nowadays) go all by the KLEPS-designations. So for example KLEPS-10, KLEPS-2600 etc.
« Reply #6 on: February 11, 2018, 10:37:25 pm »
Here's another source:
https://www.banggood.com/DANIU-P5004-Professional-Insulated-Quick-Test-Hook-Clip-High-Voltage-Flexible-Testing-Probe-p-1103049.html?rmmds=detail-left-hotproducts__6&cur_warehouse=CN
Yes, this was like the one i brought from ebay!!
Hey great, this might come in handy for another time, just googled KLEPS and a lot of other probes came up too.
Cheers guys
Offline timelessbeing
« Reply #7 on: February 12, 2018, 01:53:59 am »
I have these ones, and they're extremely vile shanzai. Be kind to yourself. Get something a bit nicer.
http://muellerelectric.com/product-category/grabbers-plungers/
« Last Edit: February 12, 2018, 01:56:04 am by timelessbeing »
« Reply #8 on: February 12, 2018, 09:01:26 am »
[/quote]
Hi, yes they didn't say what they where hooks or grabbers so for a couple of quid I brought them. But like the link you put I got some of these coming from eBay. Many thanks
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #9 on: February 12, 2018, 09:20:24 am »
I guess even manufacturers are unsure what to call them.
KLEPS 30: Clamp-type test probe with rotating grip jaws and flexible shaft.
« Reply #10 on: February 12, 2018, 09:24:45 am »
I guess there might be some copy rights if people are not careful!
Offline Hydron
« Reply #11 on: February 12, 2018, 11:41:22 am »
See OpenTechLab for a discussion of the mini-grabber type probes:
https://www.youtube.com/watch?v=dobU-b0_L1I?t=2087
and the wiki page: https://sigrok.org/wiki/Probe_comparison
The following users thanked this post: mos6502, chefslot
« Reply #12 on: February 12, 2018, 11:57:25 am »
Excellent find that is!!
Offline Hydron
« Reply #13 on: February 12, 2018, 05:16:20 pm »
Bad news is that there isn't a cheap but good option - you get what you pay for!
Offline LaurentR
« Reply #14 on: February 12, 2018, 06:05:05 pm »
I find that EBay has a lot of the Tek ones at very competitive per-unit price (new old stock usually).
Example listing:
https://www.ebay.com/itm/Lot-20-Tektronix-SMT-KlipChip-Mini-Grabbers-206-0364-01-Adapter-Test-Clips/152884514465
I have a bunch of the Cal-Test version (which seem to be the Tek OEM) and they are pretty good, very competitive with the other mid-range probes like the EZ-Hook.
http://www.caltestelectronics.com/ctitem/49-clips-surface-mount-device-smd-tweezers-a-test-clips/CT3659
The following users thanked this post: Hydron, chefslot
Offline Hydron
« Reply #15 on: February 12, 2018, 08:59:14 pm »
Thanks, I'll likely grab a couple of bags.
