Author Topic: DSO/MSO Instrument Carry Case: Rigol vs Agilent/Keysight  (Read 11766 times)
Offline amorim317
Re: DSO/MSO Instrument Carry Case: Rigol vs Agilent/Keysight
« Reply #25 on: February 18, 2020, 10:59:55 am »
Hi Sparky, i wish i find you well, i see it is an old post, but i still have a question that i didn't see on other commments..
is the rigol bag, suitable for the keysight dsox2000 models? does it fit?
thank you.
Offline SparkyTopic starter
« Reply #26 on: February 19, 2020, 05:14:52 am »
thank you.
Hi amorim317, I don't have first-hand experience of this, but I'd say it _might_ work: DSOX2k series is notably bigger than the Rigol DSO2k series, but also the Rigol bag is spacious and you can remove the dividers to adjust the size.
But, don't take my guess as recommendation.  I suggest you to look up the datasheet from the relevant scope and compare the physical dimensions.  With that knowledge of how similar they are in size compare with the photos in the original post to form your conclusions.  Someone else here might have first hand experience, but that is best I can suggest for now.
Good luck!
