I have a UNIT UT61E+ multimeter, everything works perfectly, except for the USB connection with windows 10, it installs the drivers automatically, I install the software downloaded from its page, version 1.03, but it doesn't work in either a usb3 or usb2 port, but it does work in windows 7 what would be the problem
in spanish
poseo un multimetro UNIT UT61E+, todo funciona perfecto, menos la conexion USB con windows 10, instala los drivers automaticamente, instalo el software descargado de su pagina la vesion 1.03, perono funciona ni en puerto usb3 ni en usb2, pero si funciona en windows 7, cual seria el problema
