Hi guys
I have a MSO5000 and are now looking into the FFT functionality and have a question for your guys.
If you take a look at the attached MSO5000 screen dumps, I use a 10kHz sine wave 1 volt PP on the FFT 1 screen dump and a 10kHz triangular wave 1 volt PP on the FFT 2.
The FFT setup is dBV and the waveform generator and the MSO is 50 ohm terminated.
My question is on the FFT 1 screen dump – the 1 volt sine wave – The FFT analysis shows the first fundamental to -9.5 dBV – If I want to find the voltage from the FFT analysis I get: Voltage = 10^(-9.5/20) = 335mV - why is it not 1 Volt – what is wrong here
