Author Topic: MSO2000 DPO2000 application module hack  (Read 2443 times)
Offline volvo_nut_v70Topic starter
« on: July 10, 2019, 04:05:19 pm »
This is just a summary of the existing threads here https://www.eevblog.com/forum/testgear/mso2000-application-module-hack/ . The two methods are re programming/creating a TDS module. The second is applying a patched firmware to the scope. I have tried the firmware and it works, the module rewrite works with the TDS3000 series (uses a 24C02) https://www.eevblog.com/forum/projects/tektronix-tds3000-oscilloscope-modules-tds3uam/msg581285/#msg581285 , didn't verify this one.
Requires host TDS3 module + 24C08 (to replace the 24C02)
http://web.archive.org/web/20140729081735/https://sites.google.com/site/blinkyoontz/hacktek
Firmware hack
https://github.com/dmitrodem/tek_softhack
Torrent links to patched V1.56 firmware (which is the latest)
https://www.nmsbt.com/nms/TEK/1-2-1-1.html
https://translate.google.com/translate?hl=en&sl=zh-CN&u=http://btdiggcn.org/0zsU-uxNllB1GGnJEDrI5krGH-A.html&prev=search
The following users thanked this post: blackfin76
Offline darkstar49
Re: MSO2000 DPO2000 application module hack
« Reply #1 on: July 10, 2019, 04:14:56 pm »
why the heck would anyone create new TDS modules   ::)
Buy some cheap TDS3FFT or TDS3TRG modules (which are useless anyway, as those options are activated by default in the TDS3K FW since an eternity), and reprogram those... done this a 1000x times !!!
Offline darkstar49
« Reply #2 on: July 10, 2019, 04:20:43 pm »
BTW, modules work for TDS3K, DPO2K, DPO3K (not for BW upgrades, but keygen available) and DPO4K.
For MDO's, there's a keygen (in this forum, didn't search...) for the MDO3K, and some work has been done for MDO4K's as well, but you'd have to check the related thread (don't remember if it's just the key that changes, or if the algo is slightly different...).
Offline blackfin76
« Reply #3 on: November 11, 2022, 11:00:20 am »
Firmware hack works like advertised, you get four application modules instead of just two with the hardware modules.
Now I no longer need to switch hardware modules to change to another serial bus decoder.
Offline [steven]
« Reply #4 on: May 30, 2024, 10:41:15 pm »
Does anyone still have the patched firmware? The link in the first post seems to be offline and I'm also having issues compiling my own firmware.
