Hi forum
I have a question regarding the SYMMETRICOM GPSDO. I bought one from ebay (
http://r.ebay.com/bhR8rN) and have some questions, maybe someone can help me - I'm completely new to this topic.
The LOCK led flashes with about 2 Hz – this is the signal for full operational DO locked to GPS – right?
On the control panel unit I can see the values for HDOP, VDOP and PDOP - I cannot realy interpret these values correctly?!
- HDOP and VDOP where in range from 1 to 3 after the first powering up at my location.
- HDOP and VDOP are now since one day 0.0.
- PDOP is now more or less around 0.3 … 0, even when only one satellite is in view.
- During the first day, the HDOP, VDOP und PDOP values where dependent on the number of satellites and the LED right to the LCD lit up, when a PDOP value was display (> 4 satellites)
- The LED never lit up again, after the HDOP, VDOP values where 0.0 even with 5 or more satellites. Is this behavior (LED, 0 HDOP/VDOP values) correct?
This is the output of posstatus - here even the PDOP is displayed as 0.0 - bug?
UCCM-P > posstatus
7/23/2016 10:50:22
Position : LAT(N 48:40:27.288) LON(E 9:14:31.206) H(361.60 m MSL)
Geometry : PDOP(0.0) HDOP(0.0) VDOP(0.0)
Channel Status
num of visible sats > 9
num of sats tracked > 5
------ Receiver Channel State ------
CH 0 > SateID(5) TrackMode(pos avail) SigValue(40)
CH 1 > SateID(14) TrackMode(pos avail) SigValue(33)
CH 2 > SateID(21) TrackMode(pos avail) SigValue(34)
CH 3 > SateID(25) TrackMode(pos avail) SigValue(42)
CH 4 > SateID(29) TrackMode(pos avail) SigValue(37)
CH 5 > SateID(0) TrackMode(code search) SigValue(0)
CH 6 > SateID(0) TrackMode(code search) SigValue(0)
CH 7 > SateID(0) TrackMode(code search) SigValue(0)
CH 8 > SateID(0) TrackMode(code search) SigValue(0)
CH 9 > SateID(0) TrackMode(code search) SigValue(0)
CH 10 > SateID(0) TrackMode(code search) SigValue(0)
CH 11 > SateID(0) TrackMode(code search) SigValue(0)
Rcvr Status(2) :
Antenna Voltage: 5647 mV, Antenna Current: 24 mA
-----------------------------------------------------------------------------Sorry for my dumb questions, but I didn't find anything in the forum on this topic.
73
Dietmar, DL2SBA
