First, I have to say that I am learning, or in other words, I have no idea what I am talking about.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
But if no one else says anything....
I have a FY3224S and a 8.2 Ω resistor and I wanted to check your question.
Also, I found a calculator for internal resistance.
https://electronicbase.net/de/innenwiderstand-berechnen/#innenwiderstand-online-rechnerSo, I measure a voltage under load (8.2 Ω) of 0.448 Vrms at 3.536 Vrms source voltage (10Vpp).
That gives 56.52 Ω internal resistance according to the above calculator.
I don't know if it's correct to calculate it this way, but the result seems halfway reasonable.
However, the waveform suffers a bit at 8.2Ω.
I think that a limit is soon reached anyway.
The question is what you expect or what can be expected.
Please correct me if I am wrong.
