Author Topic: Oscilloscope BNC mating cycle ratings ?  (Read 5935 times)
Online nctnico
Re: Oscilloscope BNC mating cycle ratings ?
« Reply #25 on: December 10, 2022, 09:09:43 pm »
Only 500 mating cycles?  This makes me wonder if 3 year scope warranty covers BNC connectors.
Have you ever worn one out? I haven't, and I have multiple scopes that are over 30 years old. A portable scope that is used in the field and gets packed and unpacked every day could have an issue but in most cases I wouldn't be worried about it.
I have had flaky BNCs on some test equipment. So yes, it is possible to wear BNCs. But age doesn't matter; the number of mating cycles does. I make it a habit of not disconnecting probes when I don't have to.
I've also experienced worn PCI slots (which are typically rated for 30 mating cycles or so) which meant throwing the motherboard away (this was in a PC used for testing boards so it did see quite a lot of mating cycles).
Offline TheSteve
  • Living the Dream
« Reply #26 on: December 10, 2022, 09:28:34 pm »
I've seen worn out BNC's on several items over the years. The locking posts were half gone. No idea how many cycles it took for that to happen. I do know I push inwards when I turn a BNC to prevent too much pressure on the pins.
VE7FM
