I don't see how a 4ma source can blow a .44 ampere fuse, regardless of the setting of the meter. Even in "off" mode, the fuse can be blown with too much current, but current lower than the fuse's rating won't.
Unless your source is defective or otherwise putting out more than 4 ma.
Are you sure the fuse wasn't blown before?
