Author Topic: Philips PM3207 fault  (Read 5221 times)
Offline BlaffetuurTopic starter
« on: February 17, 2014, 02:20:05 pm »
Yesterday I bought
scope 2nd hand for €40 =)
Brought it home, turned it on and I got
I didn't have probes so I couldn't really test it, but I could change de vertical position, in xy mode I got a dot and when changing the volts/div you saw the line get "distorted".
After playing with the knobs for a while all I've got was 1 line on screen.=(
I think it was when changing the trigger from ac to tv but I'm not shure.
Now I can't adjust the vertical position and in xy mode I get nothing.
Here is a video of me noodeling with the knobs.
Also on the
it says 220V and I
230V, is this a problem?
Here is the manual.
Today I've got probes and when connecting the probe to probe adj. I also get notting.
Here is a video af that.
Does anyone have an idea?
Thanks
Edit: In the video's it's on ADD but I tested it and on A&B it does the same thing.
(Edit2: or maby it happend when switching between alt and chop mode)
« Last Edit: February 17, 2014, 04:21:28 pm by Blaffetuur »
Offline London Lad
Re: Philips PM3207 fault
« Reply #1 on: February 17, 2014, 02:33:57 pm »
Its doing more or less what I would expect it to do.
Switch the AB / ADD switch back to AB
« Reply #2 on: February 17, 2014, 02:43:05 pm »
When I switch to A&B it gives me the same result.
Offline London Lad
« Reply #3 on: February 17, 2014, 03:16:56 pm »
Connect your probe to channel A and take it off the probe adjust clip. If its got a switch on it,set it to x1
Adjust the 'volts/div' and 'trigger level' and you should see noise when you touch the probe tip with you finger.
« Last Edit: February 17, 2014, 03:30:42 pm by London Lad »
« Reply #4 on: February 17, 2014, 03:39:06 pm »
Tried it, can't see noise
Video, sorry if the video seems a bit rushed :p
« Last Edit: February 17, 2014, 03:53:10 pm by Blaffetuur »
Offline London Lad
« Reply #5 on: February 17, 2014, 05:01:50 pm »
I can't see the triggering in your last video.
Use input A then set triggering to  'A' '+' 'INT' and 'AC' then use the small trigger level knob.
Try a paper-clip in the A BNC just to check your probe isn't shorted.
If you cant see any noise try probing a battery.
« Reply #6 on: February 17, 2014, 05:23:19 pm »
Tried everything you said but still the same stupid line.
