Author Topic: Siglent SDS & SDG Hack Script  (Read 26554 times)
Offline Zigortxu
Re: Siglent SDS & SDG Hack Script
« Reply #50 on: January 28, 2023, 12:10:44 pm »
Thanks very much, I connected by telnet but dont changed the port number to 5024, so I havent connect, after read your post changed the port and connected fine.  Thanks very much
Offline azaaxx
« Reply #51 on: February 13, 2024, 11:47:39 pm »
Has anyone tested this method for SDG1025 ?
I`ve tried and it is not working for me.
I have tested it with old firmware (with possibility to activate BW license from scope UI) and with newest (BW License removed from UI)
Offline ton4eff
  • Country: bg
« Reply #52 on: April 01, 2024, 08:56:12 am »
No problems with SDG2042X to SDG2122X. Thank you!
2091587-0
Offline H.O
« Reply #53 on: April 02, 2024, 04:43:32 pm »
On the SDS 2k+ there's the option to install license for ARINC (ARINC 429 I suppose).
I can't find it mentioned in any manual and it does not seem to be an option for sale for the 2k+ (I do see it for the 7k, 5k, and 3kHD).
I've tried generating keys for various keywords ('ARINC', 'ARIN', 'ARC', 'ARINC4', 'ARINC429') to no avail.
I don't need it, I'm just curious since it does not seem to be mentioned anywhere. Yet it's there and available as a selectable decoder and my trial counter is now at 29.
Has anyone been able to get it going?
EDIT: From another thread, on the same subject - apparerently the keyword is 'A429'.
« Last Edit: April 02, 2024, 07:49:53 pm by H.O »
Offline Mahagam
« Reply #54 on: April 02, 2024, 05:28:15 pm »
I`ve tried 'ARNC' also, without success.
Offline james38
« Reply #55 on: April 02, 2024, 11:32:59 pm »
Use this: A429
Offline aronake
  • Country: hk
« Reply #56 on: May 14, 2024, 03:44:00 am »
From what I have read in other threads this seems to work with SDS800X HD series.
But does it work with SDS1000X HD series? I can not find any information about this.
It seems it do not work for SDS2000X HD and SDS3000X HD.
Offline mcconkeyb
« Reply #57 on: May 27, 2024, 03:17:05 pm »
I am also looking for the answer to this question. It would be nice to hear from someone who has 1 of these latest HD models and has tried this "procedure".  8)
Offline hansibull
  • Country: no
« Reply #58 on: May 27, 2024, 06:22:33 pm »
I can confirm the script works on the 1000X HD series. Just follow the steps provided in the first post.
The following users thanked this post: mcconkeyb, Markus2801A
