Fine, I'll spell it out explicitly: what is the practical difference between a free market in which sellers are forced by law to be honest about the safety characteristics of their wares, and a "free market" in which manufacturers are forced by law to build their goods to a minimum safety standard
One requires the buyer to be educated/informed about every single thing they ever buy and places all the responsibility on them for failure to know enough math/physics/chemistry/statistics/history/biology/etc. Experience has shown that this doesn't work (buyers aren't educated, sellers aren't transparent, unfit wares are sold).
Then what prevents the person in question from buying something that meets the minimum safety standard, but doesn't meet
his safety needs as a result of those needs exceeding the minimum that the standard targets?
Remember: These are the same buyers who believe all that new age woo-woo crystal energy crap is "science". You're expecting them to understand building safety standards?
Not necessarily, but I do expect them to realize when they're in over their heads and to seek help when they are.
When did the whole notion of personal responsibility (which clearly includes responsibility for one's family) go out the window like this? I understand the notion of protecting people from the actions of others, but that seems really valid only when the people being protected have no responsibility relationship with the people they're being protected from.
If you go all the way down that road, then you effectively take away all responsibility one has for those that would otherwise be his responsibility, right? After all, what's left to be responsible
for when the state dictates everything you can and cannot do with respect to those things that can endanger those you would otherwise be responsible for?
The other system places responsibility on the seller. The seller will produce a better ware simply to cover his ass when the lawyers turn up ("I demonstrably built it to code, so... ").
Why would the lawyers show up in the case of an enforced minimum standard but
not when there's the absence of one? And remember that lawsuits are
always decided case by case, on the basis of the facts presented in the case itself, which means that the actual standards that the product was built to will come up and be evaluated whether or not there's an enforced minimum standard involved.
I dunno but option (b) seems more likely to produce safe goods for the general public.
That is more likely than not to be the case, of course, if only because option B would set a safety floor. But if the goal were to
maximize safety, then there would be one allowed, enforced standard and it would be the maximum one possible, would it not? After all, you can't
guarantee that the product in question will be always used under conditions that some lower-than-maximum standard would be sufficient for, right?
(and the two things aren't equivalent at all, I don't how anybody could think they are... )
Well, in the presence of only one safety standard covering the same thing, that the supplier could neither fall below nor exceed, then yeah, they wouldn't be. But since we're talking about a situation where, when a minimum safety standard is mandated, suppliers can exceed those standards
and advertise that fact (if only to differentiate their products from the ones that only meet the minimums), then the buyer is still faced with having to make safety-related choices. And being faced with multiple choices introduces the possibility of making the
wrong choice, at least if there exist conditions that exceed the protective abilities of the minimum safety standard (if there are no such conditions, then what's the point in building to any higher standard than the minimum? In that case, the minimum and the maximum are the same in terms of necessity).
When you put all of that together, I don't see how those things
aren't equivalent, at least as regards the problems the buyer will face. The potential for harm is still there even with the minimum safety standard in place, right?
