Author Topic: Minipa ET-997 $50 MultiMeter Review  (Read 22515 times)
Offline metalphreakTopic starter
  • http://d.av.id.au
    • D.av.id.AU
« on: December 03, 2010, 02:00:12 pm »
http://www.minipachina.com/products-16893-5714-item-17432.html
Got mine from DealExtreme for $38.29 so this falls into the Sub $50 range :)
http://www.dealextreme.com/details.dx/sku.42269 Quite a few user photos there too.
Has the usual Volts/Amps/Resistance stuff. Resolutions for each mode are on the minipa website. Also does capacitance, frequency, and duty cycle.
CAT II 1000V rated meter.
Test probes are CAT III 1000V / CAT IV 600V Rated. Mine also came with the temperature thermocouple. The carrying case is a nice touch. It's not padded but it'll protect your meter from scratches etc.
Dave will be disappointed to know the short circuit tester/buzzer is latched and has a bit of a delay. The fuse is not accessible without dismantling but the main fuse is "resettable". The screw for the battery cover has a threaded insert :P The autoranging is reasonable. It's not instant but it usually finds its way within a second. Backlight is white and lights up the display quite evenly.
Now, time to tear it apart  ;D
Back Panel Off
Front of PCB (LCD lifted and hinged on the LED backlight leads)
Where the action happens
Main IC FS9922-DMM3
The entire package
All up I'm pretty happy with it as a cheapy meter. Nothing about it annoys me. I don't have a Fluke or anything to compare voltage/current readings with but it reads a solid 5.00V on my regulated bench PSU.
I know Dave can't review the many hundreds of sub $50 meters out there but here's another (in my opinion) good option to consider when buying.
Hmmm looking at the datasheet, looks like it also has RS232 :D Pin 94 Low enables TX on Pin 92. I'll have to take it apart again, but it doesn't look like those pins are connected to anything on the PCB.
« Last Edit: December 03, 2010, 02:18:21 pm by metalphreak »
Offline saturation
  • Doveryai, no proveryai
    • NIST
Re: Minipa ET-997 $50 MultiMeter Review
« Reply #1 on: December 03, 2010, 07:45:19 pm »
Nice.  Have you tested its accuracy?
Best Wishes,
 Saturation
Offline BillGeo
« Reply #2 on: December 27, 2010, 11:55:23 pm »
How can one test the accuracy of a DMM, if one doesn't own another measurement instrument, a more precise and/or calibrated one?
Offline mzacharias
« Reply #3 on: December 27, 2010, 11:58:35 pm »
At the very least you can measure a brand new AA alkaline cell. If it reads about 1.56 or so at least you're close.
Offline BillGeo
« Reply #4 on: December 28, 2010, 05:15:50 am »
I guess you could do that. But what about self discharge?
You wouldn't know how long the battery has been on the self.
Offline saturation
    • NIST
« Reply #5 on: December 28, 2010, 11:44:10 am »
You'll need a friend or find one at work  :D
In the end a good test of a meter is how it measures, as that's what its made to do.
Best Wishes,
 Saturation
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #6 on: December 28, 2010, 07:19:22 pm »
In my village this only fuse , called as exchangeable ..
resettable= an automatic Fuse , that disarms and arms back manually.
And another thought ..  Lots of trimmers in it !!
If something has so many trimmers  (potentiometer) in it , I would expect that it comes with an 50 pages calibration manual ..
Yes its a cheapy ,  but behind any cheapy , its an cheap products manager !!
And I suggest to let him with out food as punishment ..    :)
Offline mzacharias
« Reply #7 on: December 28, 2010, 07:58:30 pm »
OK, but self-discharge is in the small microamp range. If it's on the shelf less than a couple years, you'd never see any drop in the battery voltage. That's not a firm rule, I'll agree, and my suggestion was only just that, a suggestion.
  • http://d.av.id.au
    • D.av.id.AU
« Reply #8 on: December 31, 2010, 08:41:47 am »
I've got a ZhaoXin RXN-3010D-II which is a dual 30V 10A adjustable power supply. It has a third 5V constant regulated output and the meter reads this fine as ~5.000V :) It also agrees with my rigol 1052E (although a scope probably isn't the best thing to measure voltage with).
You don't buy one of these to do critical measurement with 0.01% accuracy, but I like the look and feel of it, and its handy to have a couple of cheapies kicking around if you want to do multiple measurements at the same time.
Should do a review of this PSU some time. Just have to think of some cool things to do with 60V and 10A >:)
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #9 on: January 27, 2011, 06:40:04 am »
wish I could do that to my production manager  ;D
Offline quanttrom
« Reply #10 on: August 23, 2011, 02:41:18 am »
I own this DMM and I also happen to have access to a whole bunch of Fluke and a bunch of bench multimeters.
Would anybody be interested in seeing how accurate it is compared to theses???
Offline saturation
    • NIST
« Reply #11 on: August 23, 2011, 10:02:06 am »
I would, please do!
Best Wishes,
 Saturation
Offline Genin
« Reply #12 on: October 11, 2011, 02:14:08 am »
+1. I also would. Please Quanttrom, do it.
Thanks a lot in advance.
Offline ablacon64
  • Country: br
« Reply #13 on: October 11, 2011, 05:13:11 am »
I'm also very interested, quanttrom! I liked very much this DMM looks, I have other Minipa models and find them very useful.
Offline gcp6ca
« Reply #14 on: August 30, 2012, 04:10:20 pm »
quanttrom, never did provide any comparisons so I thought I would for others that might be interested. I actually bought a second one since I like the first one and in general it is fairly close to a Fluke 89 IV (about 0.2% or less). This post has DC voltage measurement photos.
Offline gcp6ca
« Reply #15 on: August 30, 2012, 04:15:01 pm »
This post has DC current (mA and uA) measurements. The Minipa ET-997 on the right has Fluke CAT III probes with alligator clips soldered at the end.
Offline T4P
  • Country: sg
    • T4P
« Reply #16 on: August 30, 2012, 04:17:32 pm »
Nice photos
Well in spec, what else can i say? The TRMS version goes for 50bucks
Hmm ... I still think UT61E is a better deal for money if you don't mind not having temp or backlight but want the peak and 22000 count feature (220mF ... 220Mohms)
Offline cookie
« Reply #17 on: September 01, 2012, 02:53:02 pm »
good share,good  tips,I got a lot
Offline saturation
    • NIST
« Reply #18 on: September 01, 2012, 04:09:26 pm »
Its also good to torture test the meters to see if the accuracy is retained under summer heat or winter cold.  Put the meter in the fridge, then freezer each for an hour and see if its still accurate.  For heat, just leave it in a box under the sun [ to keep UV rays from bleaching it] or you can put it in an oven, try to get ambient to reach  <= 120F, for an hour.
Best Wishes,
 Saturation
