Author Topic: Micsig TO1104 wishlist  (Read 5429 times)
Offline PlainNameTopic starter
  • Country: va
« on: January 09, 2018, 08:08:55 am »
Is there already a topic for a wishlist for this scope, or a better place to catch the eye of someone who can make things happen?
I am getting slightly annoyed from having to slide the trace about every time I change the timebase - it zooms in on the centre of the screen, and what it really needs to do (it seems to me) is to keep the trigger point static and zoom in around wherever that is on the screen. All too often I have the trigger two grid lines in on the left, need to zoom in on the trigger position, and the very next capture after increasing the timebas shows nothing because the trigger is now off-screen to the left. Lots of sliding later I can now do another one-off trigger....
Offline kirill_ka
  • Country: ru
Re: Micsig TO1104 wishlist
« Reply #1 on: January 09, 2018, 11:56:53 am »
What should it do if the trigger point is already off the screen?
  • Country: va
« Reply #2 on: January 09, 2018, 12:42:39 pm »
A good question. In that case it should zoom to the left edge, I think.
But perhaps it is academic, though. Since posting I've rediscovered double-tapping to zoom where you tap, which makes the desired effect achievable easily. Duh. Also one can use the 50% positioning to bring the trigger back to the middle of the display, which is kind of a halfway house.
Offline Rob_R
« Reply #3 on: January 09, 2018, 04:50:28 pm »
When my T01104 arrived , there was a film screen protector included with it..
After watching Mikes tear down and Micsigs official screen protector fitting video ,I wish they'd factory fitted during assembly .
Rob
  • Country: va
« Reply #4 on: January 10, 2018, 12:53:32 am »
Yes, I fully agree! Micsig kindly sent me a spare when I screwed up putting it on, and I still didn't get it right,  but it's now good enough. Factory fitting would save a lot of aggro :)
Offline TK
« Reply #5 on: January 10, 2018, 01:33:13 am »
You can bring the trigger point to the center of the screen by using the 50% button on the right
  • Country: va
« Reply #6 on: January 10, 2018, 01:39:45 am »
Yes, belatedly remembered that, thanks. Better than nothing :)
Online nidlaX
« Reply #7 on: January 10, 2018, 01:44:51 am »
Keep posting your suggestions here, I will go over them with the Micsig rep.
  • Country: va
« Reply #8 on: January 10, 2018, 01:54:51 am »
Thanks!
Another one relating to zoom (rather, timebase change) is the horizontal cursor. When zooming in or out I would expect the cursor to scale as well, so the measurement remains the same until you manually change it. Same applies for vertical cursor and probe sensitivity too, of course. It can get tedious to want to zoom into something and then spend a few minutes dicking with the cursors again to get back where you were. Often it is simpler to leave them alone and then zoom back out to check the measurement.
Offline kirill_ka
  • Country: ru
« Reply #9 on: January 11, 2018, 09:18:17 am »
1. Display numeric value when adjusting vertical position of waveform using "Fine" buttons.
2. Don't hide numeric value then adjusting trigger level using "Fine" buttons.
3. Make auto/normal/roll trigger setting more accessible. Perhaps use dedicated trigger button to change those and some other frequently used trigger settings instead of just invoking a menu.
Then tapping on the trigger information at the top of display may be used to call trigger menu.
  • Country: va
« Reply #10 on: January 11, 2018, 09:57:01 am »
Or a user-assignable button(s) so the user can decide what he'd like fast access to.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #11 on: January 11, 2018, 10:12:39 am »
Something that Chinese scopes like this often omit is to be able to have the zero-reference at the left or right (1 div from edge) of the screen as additional options to having it at the the centre.
You are almost always most interested in what happens before OR after the trigger, so these make more sense than having it at the centre.
Day Job: Mostly LEDs
The following users thanked this post: GeorgeOfTheJungle
  • Country: va
« Reply #12 on: January 11, 2018, 10:16:34 am »
the zero-reference
Thank you - that's what I meant rather than trigger. I am too used to Tek and HPAgilentKeysight kit and, obviously, never had to think about it with those.
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #13 on: January 11, 2018, 06:52:18 pm »
Yes, +1, manufacturers please, hear, hear !
(and with a direct button too, not hidden 3 levels deep into the UI please)
« Reply #14 on: January 11, 2018, 08:46:34 pm »
Not a huge deal as long as it's persistent over a powerdown I pretty much always have it set at left.
  • Country: tr
« Reply #15 on: January 12, 2018, 04:01:17 pm »
Knobs and buttons: more is better.
« Last Edit: August 13, 2018, 03:10:52 am by GeorgeOfTheJungle »
Offline targit
« Reply #16 on: March 08, 2018, 03:06:20 pm »
Hi, stupid question time, not sure if this is the place to ask, is there a way to view the reference waveform files generated from the "Quick Save" button without attaching the scope to the PC that I want to view them on? They are saved without extension and so far I can't find anything that opens them in any meaningful way.
Offline newnet
  • Country: ru
« Reply #17 on: June 05, 2018, 07:43:22 am »
I think a pop-up Matrix Keyboard will be more suitable and convenient for changing or selecting timebase quickly on a touch-screen.
Offline SteveOregon
« Reply #18 on: July 07, 2018, 10:22:10 pm »
I haven't found anything that will open those files. The work-around; is to display the reference waveform on the scope, then do a screen capture with the camera icon - which copies the ref file to png.
« Last Edit: July 08, 2018, 03:38:38 pm by SteveOregon »
Offline hgjdwx
« Reply #19 on: July 08, 2018, 10:05:47 am »
like this
The following users thanked this post: targit, Micsig_support
Offline StillTrying
  • Country: Broken Britain
« Reply #20 on: July 08, 2018, 10:49:10 am »
Does it do 5ms/div or is it still 4ms/div.
Offline SteveOregon
« Reply #21 on: July 08, 2018, 03:45:21 pm »
With latest firmware; 5ms/div, 2ms/div, 1mv/div (lowest)
The following users thanked this post: StillTrying
Offline xavier60
« Reply #22 on: August 11, 2018, 10:25:58 pm »
It puzzles me that this unacceptable oversight is rarely mentioned.
A DSO without the ability to set the trigger zero-reference to the Left would be unbearable for me to use.
So be certain to check for this before choosing a DSO to avoid possibly being disappointed.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline StillTrying
« Reply #23 on: August 11, 2018, 11:19:56 pm »
"A DSO without the ability to set the trigger zero-reference to the Left would be unbearable for me to use."
I think almost any scope user designing a DSO would put the default trigger position about 2 Div. in from the left, especially if there's often going to be menus covering the right half of the screen.
DSOs always have a bad Usability Interface IMO.
Offline Micsig_support
  • Country: cn
  • Manufacturer of digital oscilloscopes from China
« Reply #24 on: August 13, 2018, 07:19:31 am »
like this
very good design!
JL
The following users thanked this post: Synthtech
