Author Topic: Recomend me a digital microscope with USB  (Read 3108 times)
Offline lordvader88Topic starter
« on: August 15, 2018, 10:30:08 pm »
I don't want a super cheap or super expensive 1, maybe $200 ? I don't really know anything about them or whats needed for electronics. But I have some cash and I want 1.
Offline DaJMasta
    • medpants.com
Re: Recomend me a digital microscope with USB
« Reply #1 on: August 15, 2018, 11:25:36 pm »
It's on the lower side for a decent microscope (at least, that's above the cheapy ones), but if you don't want to go with the low tier, maybe the Aven Mightyscope 5M?
There are some reasonable ones on the real cheap end, but you'll run into limitations with illumination/optics/software/etc.  When I was looking around my budget was a bit more, but I ended up deciding I didn't want a USB scope, cause generally the framerate at good resolution is not all that high and not suitable for soldering under, though it works for inspection.  If you consider used, there are some DinoLite scopes with VGA output in this ballpark, and that would be a notable improvement in optics, build quality, and framerate over most of the <$200 options, though the brand typically runs pricey for new scopes.
« Reply #2 on: August 16, 2018, 01:11:15 am »
I should say I don't 1 with eyepieces for me to look through
I would like high enough resolution to examine/ clearly save and map out SMD PCBs, that will be the main use for now
And I should be-able to SMD solder under it, I'm not repairing motherboards yet but I don't want to buy 1 now and then need another 1 later.
I'd say there's $20-50 scopes that would do fine for most stuff I'm doing now, and I won't be using it that often. But I can justify more money
Offline billfernandez
« Reply #3 on: August 16, 2018, 05:02:55 am »
I have (and like) the Adonstar HDMI Microscope.  It's in your price range.  Here's a thread about it:
https://www.eevblog.com/forum/manufacture/the-andonstar-hdmi-microscope-thread/
Offline Candid
« Reply #4 on: August 16, 2018, 06:32:55 am »
The video from KainkaLabs may be helpful for you:
https://youtu.be/6-erG5yUDmw
« Reply #5 on: August 17, 2018, 06:06:49 am »
wow I just started the video and 1 of those head gear things would be nice
Offline Candid
« Reply #6 on: August 17, 2018, 08:28:25 am »
