BTW, concerning bundled probes. I tested them against PP-150 (perhaps, cheapest probes on market). I used my SDG2042X to generate some 120MHz 1Vpp sinewave. Bundled probes showed 576mV, PP-150 showed 792-800mv peak-to-peak. So, I replaced my bundled probes with PP-150 (I bought five of them just in case and one come already broken, he-he).
The test was crude, I used long wires, ground leads, crocodile clips, etc. So, not the most accurate setup (because I lost my the only probe bnc adapter I had). But I suggest replacing shipped probes if measurement accuracy above some tens of Mhz is important. Anyway, I don't mind if someone repeats my measurements.
