From the specs, the TO1104 has bandwidth limit of 20MHz, high pass, low pass while the non-Mini versions do not support high pass and low pass filtering. Does that mean the mini version is better?
Somewhere I read that different manufacturers have different definitions for the max capture rate and memory depth. Am I correct? I am trying to decide among various Micsig models.
For Max capture rate, which would be sufficient and recommended?
80K wfm/s, 250K wfm/s or 500K wfm/s
For memory depth, which would be sufficient and recommended?
18Mpts, 28Mpts or 90Mpts?
Between the two variables, which is more important?
