I got one, declined card, paid with paypal, then it said it didn't go through, then finally it said the order is processing so I can't submit it.
Hope for the best!
I have a new Stripe credit card option, a couple of cards have failed since I started it, no idea why, that's a Stripe thing.
There are no pending orders, so yours must be in there.
Got one, paid with Sripe and the transaction went through without problems (Mastercard). By the way I paid with Stripe because I suppose that the fees are better than PayPal, is that true? What payment method should we choose to maximize your profit?
PayPal is 2.4%, stripe is 3.2%. I just offer both for convenience.
The stripe USD to AUD conversion was more favorable for me. 535.38 AUD turned into 400 USD to for paypal and but only 385 USD with stripe(and Visa). I didn't know their fees were higher
Stripe apparently uses the forex spot price.. PayPal wants a foreign transaction fee
Wow, that's significant.
I buy in USD but sell in AUD for various reasons so either have to keep adjusting my prices as the exchange rate changes, or win/lose as it fluctuates. So that US$365 price in AUD equivalent is just what xe.com told me today.
I'm glad I went with the convenience option (PayPal One-Touch) then if you got an extra few bucks out of it. I considered using Stripe as I thought it might have lower fees.
(Edit because I can't speel)
Are the sensors accessible to read off the part number? I don't think this probe use a hall effect sensor, hall sensors don't have the bandwidth.
I think I'd have to crack it open somehow, seems glued in place.
Two 4 pin SIP packages, one marked 8877, the other one not marked, possibly mounted backwards.
Thanks for opening one up and taking the photos Dave, I'll be telling work to buy one but 99% chance they sit on it until you're sold out.
Any chance that you can check the gain that the AD8421 is running at? Should be as simple as measuring the resistance between pins 2 and 3 of the IC. I assume that the relay will change gains (hence the two trimpots) but should be easy enough to tell what the default gain is - it'll be the startup gain if the relay doesn't click on power-up, or the other one if it does.
They most likely use a TMR sensor made by Multi Dimension, something like this: https://www.aecsensors.com/components/com_virtuemart/shop_image/product/Magnetic-Tunnelling-Magnetoresistive-(TMR)-Linear-Sensors/pdfs/TMR2503-Datasheet-EN-V1.0.pdf
I am unsure why they use two sensors. My best guess would be that the outputs are summed to improve SNR or to reduce the impact of stray magnetic field.
Looks like the design is a basic analog front end with a microcontroller for the user interface and auto zeroing, pretty similar to the current probe I am designing based on a higher bandwidth AMR sensor.
wow i had no idea tmr sensors are now mass produced, thats wild... i'll have to remember this nugget now..
Full album here:
https://www.flickr.com/photos/eevblog/albums/72157715635511053
Uses an AD8421 inamp on the front end with dual hall effect sensors and relay switching.
Micsig CP2100B Current Probe Teardown by Dave Jones, on Flickr
Still I can´t believe they´re so cheap to buy - Even when this clamp would costs three times more, the value for money would still be great.
Wow, just wow.
I wonder what the differences between the 800khz and 2Mhz versions are...and where.
Edit:
Not sure if I'll bother to carry the CP2100A model?
Why not, it got the same incredible quality and with appx 200 buck it would be more affordable.
Looking for other brands, you won´t find 800khz bw under 1000 bucks and more.
Hope for the best!
Stripe failed me, but PayPal worked a treat. Thanks Dave!
I'm excited to get my hands on something that approaches thousands of dollars of value for so much less.
Wow, just wow.
Edit:
So get that A model and take some pictures
Really though i'd 99% bet on it being just some chippies OR.. more than likely it is this.. they are binning them. Why? Dave already said it himself.. they couldnt keep up with producing 2.5MHz rated versions... almost certainly means they were rebranding them as the lessor A model via binning. So you are really just paying for better quality parts
Also of interest there is a little known X version that was suppose to be rated for only up to 300 kHz
Wow, just wow.
Edit:
I doubt they are binning them, this is a pretty commodity thing.
The only non-jellybean part in there is the TMR sensor, and those are a relatively mature part ( I ordered some samples off amazon for a few dollars a few months ago). If there was variance on the TMR sensor it would be pretty simple to bin them before assembly.
This device is a good deal for what is on the market right now, but the production costs are pretty low. I would not be surprised if the most expensive parts of the whole thing was the nice plastic case and the custom mechanical components. The big change is this is the first design on the market using a higher bandwidth magnetic sensor as opposed to a low bandwidth hall effect sensor used on the cheap probes, or the hybrid hall effect + current transformer used on the super expensive current probes.
Oh, interesting....
Never saw it before, looks like a tek/hioki clone.
Noisefloor 1mVrms=10mArms, accuracy 3%.
Hm-hm...Interesting.
If Micsig could pull out the technical design and real good building quality at such a low price, these "alternatives" are much more overpriced:
Rigol RP1002C for 1886€
Testec TT-CC990 for 1178€
R&S RT-ZC02 for 898€
Siglent CP4070A for 842€
