Hi everyone, for some time I have this signal generator, 25Mhz two channels, it is working, with a USB connection to the PC and related software.
On the rear panel it has, among other things, the outputs of channels CH1 and CH2 "power out" but connecting the oscilloscope probe I can't find any signal, do you have any information about it? maybe something wrong? In any case I can't understand what this output is for and if it probably doesn't work. I tested the front output ch1 and ch2, they run perfectly
In the manual it indicates it as a connector on the rear panel but does not specify anything else.
In the photo (internally) you can see on the left the voltage regulator board with a lot of cooling ...
I thank in advance whoever wanted to help me understand.
