Author Topic: MHS-5200A Serial port communication error  (Read 371 times)
Offline trebiTopic starter
  • Country: hu
« on: September 14, 2024, 11:56:09 am »
Hi guys,
I would like to ask for a little help.
I want to write a simple program in C#. Unfortunately, I get stuck at the beginning. I can't communicate with the device via serial port.
I always get a timeout exception error...
What am I doing wrong?
See my code
            try
                // Serial port setup
                serialPort = new SerialPort("COM5", 57600, Parity.None, 8, StopBits.One)
                    Handshake = Handshake.RequestToSend,
                    ReadTimeout = 500,
                    WriteTimeout = 500
                // Open Port
                serialPort.Open();
                // Stopping the device's own program(s6b0)
                string stopCommand = ":s6b0\r\n";
                serialPort.Write(stopCommand);
                // waiting
                System.Threading.Thread.Sleep(500);
                // Simple inquiry
                //:r1c returns :r1c323(firmware 3.23)
                //:r2c returns :r2c015(last digits of P / N ?)
                //:r0c returns :r0c52A(model #? 5200A?)
                serialPort.Write(":r0c\r\n");
                // waiting
                // reading answer
                string response = serialPort.ReadLine();
                // We display the content of the response
                MessageBox.Show($"Device response: {response}", "Response", MessageBoxButtons.OK, MessageBoxIcon.Information);
            catch (TimeoutException)
Thank you in advance for your answers.
Offline NE666
Re: MHS-5200A Serial port communication error
« Reply #1 on: September 14, 2024, 12:07:11 pm »
I think you're more likely to get an informed answer here, given the subject matter; https://www.eevblog.com/forum/testgear/mhs-5200a-serial-protocol-reverse-engineered/50/
However, if you'd like a guess - are you sure that a) hardware flow control is really being used (instead of software/XonXoff) and b) if so, you're wired up correctly?
The following users thanked this post: voltsandjolts, Kean
Online Kean
    • Kean Electronics
« Reply #2 on: September 14, 2024, 12:16:29 pm »
I'd suggest first trying no handshake in case of a cable problem.
serialPort.Handsake = Handshake.None;
Also, if the line endings are always CRLF, you can set
serialPort.Newline = "\r\n";and then use WriteLine() without including the line ending.
ReadLine() will also expect the same line ending which is sometimes a problem.
  • Country: hu
« Reply #3 on: September 14, 2024, 08:17:08 pm »
Thanks for the answer.
I have tried all the suggested options but no change. The cable must be good, it communicates with added software. However, I noticed that the factory software sees it as MHS-5212A.
Offline NE666
« Reply #4 on: September 15, 2024, 08:04:48 am »
If it were me, and I'd not done so already, I'd put my own code aside and verify whether or not I could access the device using a "proven" serial terminal program (e.g. putty) using the same serial settings. Eliminate any possible serial misconfiguration issues first ahead of suspecting a problem with your code or libaries.
  • Country: hu
« Reply #5 on: September 18, 2024, 02:53:37 pm »
Thank you for your help, communication via serial port is working. 8)
Offline ledtester
« Reply #6 on: September 18, 2024, 04:09:48 pm »
Does this Python module work for you?
https://www.eevblog.com/forum/testgear/python-module-to-control-mhs-5200a/
Could be a starting point for figuring out what you C# problem is.
