Author Topic: Tektronix TDS-3000 looking for firmware version 3.39  (Read 1652 times)
Offline matthTopic starter
« on: April 20, 2024, 06:33:37 am »
I have a Tektronix TDS-3034 which is running firmware version 1.10 and I need to update this to version 3.39 to do the bandwidth hack.
Has anyone got a copy of 3.39 that they would be willing to share with me please ?
Regards
M
Offline alm
Re: Tektronix TDS-3000 looking for firmware version 3.39
« Reply #1 on: April 20, 2024, 12:06:45 pm »
The following users thanked this post: coromonadalix
Online coromonadalix
« Reply #2 on: April 20, 2024, 07:57:44 pm »
and have fun getting some good floppies   :-+    had fun to find a few to do an upgrade
Do read the text file in the zip   :-+
Offline alm
« Reply #3 on: April 20, 2024, 08:04:39 pm »
Or if you want to use a more modern USB stick or SD card: https://www.eevblog.com/forum/testgear/tds-1000-2000-3000-bw-hack/msg5397158/#msg5397158.
« Reply #4 on: April 22, 2024, 06:37:33 am »
I got the firmware (thanks to someone that sent it to me) and I have now successfully updated my 3034 to a 3054 with the latest firmware.  Now all I need to do is crack open the Dallas chip, put a new battery on that and then replace the dead CCFL tubes.
Offline alm
« Reply #5 on: April 22, 2024, 02:39:45 pm »
What was wrong with the firmware uploaded in the thread I linked that you needed someone to send it to you? It might be worth sharing that firmware here.
« Last Edit: April 22, 2024, 02:42:26 pm by alm »
