Author Topic: Questions About Ancient HP 3300A Function Generator  (Read 3859 times)
Roy Batty
  • Guest
« on: January 03, 2017, 12:21:36 am »
So long, and thanks for all the fish.
« Last Edit: June 25, 2017, 03:17:57 pm by Roy Batty »
Online Andy Watson
Re: Questions About Ancient HP 3300A Function Generator
« Reply #1 on: January 03, 2017, 01:20:56 am »
Doh! Managed to delete rather than edit my post!
The schematic shows a fuse and a power switch in one line. The other line leads to the transformer and the voltage selector switch. I would connect the Hot to the fuse/power switch line. It should be easy to trace the appropriate wire back to the fuse holder.
Offline tautech
« Reply #2 on: January 03, 2017, 05:44:55 pm »
Google "dim bulb tester" and knock one together.  ;)
You'll recover the small time and cost to make one in money saved from saving fuses.
Offline tautech
« Reply #3 on: January 03, 2017, 06:09:13 pm »
I have one sitting here, plus a Variac. Thanks for the suggestion. I didn't expect it to have this particular kind of problem............
It's wise to place at least a dim bulb tester in the mains supply of ANY equipment that's been unused for some time and if all seems well then a Variac turned down some to let the E caps reform to their correct values.
« Reply #4 on: January 03, 2017, 08:11:40 pm »
My bet is C7 or C8  on the mains input side have crazed and gone short circuit. Those Rifa clear case capacitors strike again.
Offline tautech
« Reply #5 on: January 04, 2017, 01:02:51 am »
I assume it must be filtering crap out.
Exactly. Values are not critical.
