No experience with this model, a few things you could check:
Traces of battery leakage or corrosion.
Poor or dirty contacts: test sockets, internal fuse holder, relays, power switch...
Bad capacitors: look more specifically around any SMPS section HV or high current source, CPU supply.
If it is still working once you are past the long startup time, going by the spec sheet, there are a number of tests you could carry out with a DMM, clamp meter, resistors to check if the PAT32 is generating voltages and currents in the correct ranges. This could point you to what section may be failing.
