Author Topic: Another Chinese LCR meter?  (Read 9782 times)
Offline reagleTopic starter
    • KuzyaTech
« on: January 21, 2013, 12:06:22 am »
Offline notsob
Re: Another Chinese LCR meter?
« Reply #1 on: January 21, 2013, 12:39:53 am »
over to frankie
Offline iloveelectronics
  • Country: hk
« Reply #2 on: January 21, 2013, 12:55:11 am »
Funny you mentioned this. I was just doing some searching and found this company yesterday. I believe this is the manufacturer's website:
www.applent.com
They seem to make some nice (looking) instruments.
Judging from the fact that it's 1kHz, I think this is the AT824 model. I don't understand why the seller has erased the maker's mark and model number on the picture though.
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
    • KuzyaTech
« Reply #3 on: January 21, 2013, 01:08:02 am »
Now we need somebody to do a teardown!
    • KuzyaTech
« Reply #4 on: January 23, 2013, 10:47:39 am »
In the process of fiddling with measuring impedance of batteries for something I am working on, it occurred to me that I already have an ESR meter. It's called SM8124 Battery impedance Meter.  It's just a 1Khz impedance meter, that works just fine with caps. And the 20Ohm limit is perfectly fine for  most caps we care of ESR for. So that plus a DMM that measures capacitance, and I am almost there. Sure I don't get all the other measurements an LCR meter would give me, but it also is dirt cheap ($50) and all-over ebay.  http://xn--tnq722av6lsjo.xn--fiqs8s/Digital-Multimeter/SM8124.htm
« Last Edit: January 23, 2013, 10:55:19 am by reagle »
Offline kripton2035
« Reply #5 on: January 24, 2013, 07:52:32 pm »
they are not that cheap. the 100KHz model is more than 400 euros, so quite more expensive than the IET DE5000 that seems a reference here on eevblog ...
Online The Electrician
« Reply #6 on: January 25, 2013, 06:21:40 am »
Have a look at this thread:
https://www.eevblog.com/forum/projects/capacitor-measurements-on-an-impedance-analyzer/
The attachments in the first few posts show plots of impedance and ESR versus frequency.  The green curves are impedance and the yellow curves are ESR.  Impedance is not the same as ESR.  Your battery impedance meter is measuring impedance (apparently), not ESR. For a battery, those two things may be the same, or nearly so (depending on the battery type and condition, I suspect), but for a capacitor they are generally not the same, unless the capacitor is quite lossy, or the measurement is made at the capacitor's series resonance frequency.
    • KuzyaTech
« Reply #7 on: January 26, 2013, 05:53:09 pm »
My thinking was - sure you measure impedance, and not the ESR with these meters. But it may be enough to see that the formerly low ESR car ain't anymore ;)
« Reply #8 on: January 26, 2013, 10:42:26 pm »
You have a point when it comes to detecting capacitors that have become defective due to large increase in ESR, but the measurement is made at 1 kHz, not the more common 100 kHz.  A capacitor with relatively low capacitance may have a 1 kHz reactance that is high enough to mask its increased ESR.
Also, if you want to measure the ESR of a non-defective capacitor, the battery impedance meter won't do the job, so it's not generally an ESR meter substitute.
Offline Hydrawerk
« Reply #9 on: January 29, 2013, 01:41:07 pm »
I would never buy a LCR meter with color graphic LCD with underlight... It just consumes too much energy.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #10 on: February 25, 2013, 01:17:10 pm »
I got one of these recently - build quality pretty good, UI a bit untidy, Mains adapter borderline. Will do  a review sometime.
Day Job: Mostly LEDs
    • KuzyaTech
« Reply #11 on: February 26, 2013, 02:36:09 am »
Battery life measured in seconds?
« Reply #12 on: February 26, 2013, 09:18:24 am »
It has 2 medium-sized lipos - not measured but probably a few hours
Offline Hydrawerk
« Reply #13 on: February 26, 2013, 01:36:20 pm »
Well, does it really work only up to 1 kHz? Is there any advantage of the color LCD?? Does it have any graph statistics, or anything similar?
« Reply #14 on: February 26, 2013, 03:59:11 pm »
There are 3 models - 1, 1+110, 1+10+100
Display colour/resolution isn't used particularly well
Offline PA4TIM
« Reply #15 on: February 26, 2013, 11:31:53 pm »
OT, about battery meaurement http://www.pa4tim.nl/?p=3550
The real complex impedance of a battery is very interesting.
You can measure the Rs by pulse loading it. But if you measure Rs + jX you notice a good battery is neutral to inductive, a bad battery is capacitive ( like >10 nF) Rs increases if the battery gets discharged but does not tell about the health, The reactance seems to be more usefull.
But to be honnest, i think I'm the onley nut who did this experiment ( even used a vna)
