what people dont realise is that capxon is one of the largest manufacturers of electrode material....
Many a capacitor manufacturer doesnt make that themselves ! So your rubycons may very well have capxon electrode laminates in them ....
this whole bad capacitor things stems from 2 misconceptions
1) in the early 2000's there was a stolen chemical formula for a dielectric . Mitsubishi chemicals had an ew electrolyte yielding a much higher capacitance density. this formula was stolen by some Chinese outfit. only they did not realize they had an incomplete formula. a key ingredient stabilizing the electrolyte long-term and over temperature was missing... the Chinese outfit sold the electrolyte to many capacitor manufacturers and they sold oodles because it was cheaper than MCM electrolyte. The electrolyte hit the fan when it turned out that after a few months to a year under heave load the electrolyte started disintegrating , giving off hydrogen gas giving burst capacitors...
2) many capacitors are wrongly applied. inexperienced designers and beancounter malpractices pick the cheapest possible part. and that may , form a technical perspective, be the wrong part. Pulse loading , esr , and other parameters are overlooked yielding prematurely dying capacitors.
especially switch mode power supply tank capacitors live a VERY hard life and are subject to pulse current with high crest factors. combine dielectric losses with esr losses and you are boiling off the capacitor over time.
1) has been solved a long time ago.
2) will only get worse. Consumer stuff has, profit wise, hit rock bottom so the beancounters are pulling harder and harder and the quality of the design 'engineers' that rolls out of the education institutes is getting weaker and weaker when it comes to understanding components. They may be very good at coding and theoretical stuff but have no understanding of part fundamentals. Having to listen to 10 lectures on capacitors and 10 on resistors is boring.... besides, the old farts that knew that stuff have long since retired and been replaced by young whippersnappers that want to teach the theoretical stuff..
