Author Topic: Brymen BM-257 pictures and mini review  (Read 41903 times)
Offline Lightages
  • Canadian po
Re: Brymen BM-257 pictures and mini review
« Reply #25 on: August 12, 2014, 10:44:58 pm »
I knew it wasn't listed as obsolete, but I just assumed it would not be updated anymore,as is the newer series.
Offline nanofrog
« Reply #26 on: August 12, 2014, 10:54:53 pm »
Makes sense from a western POV (internal competition), but there must be a reason they've not done that.  Perhaps it's to fill a more affordable price point for 50k count meters in developing nations/markets, such as China and India (i.e. BM86x series doesn't sell well due to higher cost?).  :-//
Offline Rifter
« Reply #27 on: August 18, 2014, 09:36:48 pm »
Brymen does not make junk. The BM257 (now BM257S) is built like the proverbial brick out house. I would not hessitate to recommend it to anyone. I now have three Brymen multimeters, and for a reason.
Im happy you recommended it to me. It arrived Friday and ive used it a lot over the weekend and its been a pure joy to use, better than any meter I have ever used previous(they were all sub$50 though).
Its fast and accurate and built like a tank, perfect for my needs, and I know the safety is there if I ever use it for higher voltages or mains work.
Offline Lightages
  • Canadian po
« Reply #28 on: August 19, 2014, 05:01:35 am »
I am glad you are happy. I am sure you will buy another Brymen in the future  >:D
Offline Warhawk
    • Personal resume
« Reply #29 on: February 18, 2016, 07:21:27 pm »
Does somebody know what is a real difference between BM257 and bm257s ?
Offline WackyGerman
« Reply #30 on: February 18, 2016, 07:30:17 pm »
The Brymen 257s has 1000V fuses now , the amp range goes now to 10 A instead of 8 A . Maybe there are some differences on the board between them . The BM 257s meets the newest IEC regulations . I am not sure if the continuity test is latched on the BM257 , but it is on the BM 257s . It is a pretty good compact meter and I like to use it  :-+
« Last Edit: February 18, 2016, 07:36:02 pm by WackyGerman »
Offline Lightages
  • Canadian po
« Reply #31 on: February 18, 2016, 07:31:01 pm »
The "S" version is just a slightly redesigned model that is meant to meet the new IEC requirements for CAT ratings.
Offline Warhawk
    • Personal resume
« Reply #32 on: February 18, 2016, 07:39:11 pm »
Thank you guys for the answers  ;)
Offline nanofrog
« Reply #33 on: February 18, 2016, 08:12:58 pm »
A Closer Look at 61010-1, Third Edition Changes might be of interest (link originally posted by EEVBlog).
Offline Mitsch
« Reply #34 on: December 30, 2016, 07:00:34 pm »
My experiences with my new Brymen BM257s, compared to my other meters:
Pros:
- nice size (my smallest meter, except my UNI-T UT210E)
- big screen, clear digits
- nice backlight
- fuses
- access to battery and fuses
- warning when jack is plugged in wrong
- update speed
- bargraph speed
- nice stand
- very nice probes with silicone wires
Cons:
- bar graph (I can't see the bargraph when the meter lies flat on the table)
- off position (why isn't the left-most position off - like on every other meter?!)
- 4mm banana adapters for the probes (when you screw them on the probes they interlock twice, but you can screw them in only if you catch the right interlock)
- in germany the extra USB-adapter is a bit pricey (25€)
Overall I like the brymen and give it a big :-+
I attached 2 pictures for you - one with backlight - one without!  ;)
The following users thanked this post: multiJ
